TLS 1.2 / TIPCLIENTHTTP:New() & httpS
is it possible to use TIPCLIENTHTTP:New() with httpS for TLS 1.2 :?:
Re: TLS 1.2 / TIPCLIENTHTTP:New() & httpS
hola jimmy , esto dice la libreria hbtip
* TIP Class oriented Internet protocol library
* Copyright 2003 Giancarlo Niccolai <gian@niccolai.ws>
* Copyright 2015 Jean Lefebvre (STARTTLS support)
el soporte lo da hbssl ,habria que revisar los parametros para enviar que version de tls usar
mirar en ssl.c
AUGE_OHR wrote: Tue Jul 18, 2023 8:52 pm hi,
Try using these dlls:
dll_tls1.3.7z
(594.58 KiB) Downloaded 185 times
, it should work for 32 bit.
You do not need to specify a specific encryption, the client should negotiate with the server itself.
A host above Windows 7 is required.
#require "hbtip"
#require "hbssl"
REQUEST __HBEXTERN__HBSSL__
hi Edward,
thx for File, i will try it
Edward,
Is there also some libs for 64bits?
Serge.
If you built hbssl using the instructions in this post https://hmgforum.com/viewtopic.php?p=71447#p71447 , you don't need any external SSL libraries. When building an application that uses hbssl, the necessary libraries will be included in the executable. See example in attachment.
hbtip64.zip
(1.08 KiB) Downloaded 101 times
Edward,
Somehow it always tries to find lssleay32 ..
Harbour 3.2.0dev (r2304211101)
Copyright (c) 1999-2023, https://harbour.github.io/
P:/hmg.3.6/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.1.0/../../../../x86_64-w64-mingw32/bin/ld.exe: cannot find -lssleay32: No such file or directory
P:/hmg.3.6/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.1.0/../../../../x86_64-w64-mingw32/bin/ld.exe: cannot find -llibeay32: No such file or directory
gcc.exe C:/Users/Serge/AppData/Local/Temp/hbmk_44snhb.dir/httspadv.o C:/Users/Serge/AppData/Local/Temp/hbmk_44snhb.dir/hbmk_2mq7xs.o P:/hmg.3.6/DB_GEN_NEW/_temp.o    -pthread  -static-libgcc  -static-libstdc++  -static -lpthread -mconsole -Wl,--start-group -l"hmg-64" -l"crypt-64" -l"edit-64" -l"editex-64" -l"graph-64" -l"ini-64" -l"report-64" -l"hfcl-64" -lmsvfw32 -lvfw32 -lhbmysql -llibmysql -l"hbvpdf-64" -lhbct -lhbwin -lhbmzip -lminizip -lhbmemio -lhbmisc -lhbtip -lsqlite3 -lhbsqlit3 -lsddodbc -lrddsql -lhbodbc -lodbc32 -lhbhpdf -lhbnetio -lxhb -lpng -llibhpdf -lhbzebra -lhbssl -lssleay32 -llibeay32 -lhbextern -lhbdebug -lhbvmmt -lhbrtl -lhblang -lhbcpage -lgtcgi -lgtpca -lgtstd -lgtwin -lgtwvt -lgtgui -lhbrdd -lhbuddall -lhbusrrdd -lrddntx -lrddcdx -lrddnsx -lrddfpt -lhbrdd -lhbhsx -lhbsix -lhbmacro -lhbcplr -lhbpp -lhbcommon -lhbmainstd -lwinmm -lkernel32 -luser32 -lgdi32 -ladvapi32 -lws2_32 -liphlpapi -lwinspool -lcomctl32 -lcomdlg32 -lshell32 -luuid -lole32 -loleaut32 -lmpr -lmapi32 -limm32 -lmsimg32 -lwininet -lhbpcre -lhbzlib   -Wl,--end-group -ohttps_adv_64.exe  -LP:/hmg.3.6/harbour64/lib/win/mingw64 -L"P:/hmg.3.6/lib-64"
I surely miss something...!
Check what libraries you have set in config of your project. For the new hbssl 3.0 64-bit you should have
libs=hbssl
libs=libssl-3-x64
libs=libcrypto-3-x64
or there is something wrong with hbssl integration.
I'm uploading my hmg.3.6 integration with OpenSSL 3 and mySQL: https://www.easypaste.org/file/GDwo7dzk ... 7z?lang=en
