Err building HMG IDE
Red2
Post by Red2 »
I want to rebuild HMG's IDE to include Jimmy's improvement.
See: http://www.hmgforum.com/viewtopic.php?f=12&t=6173
Running c:\hmg.3.4.4\BuildLib32.bat I get:
* HMG-Unicode Build Library *
Build HMG Library to support the character set:
1 - ANSI
2 - UNICODE
0 - Cancel
Select an Option [0, 1, 2] (for default: UNICODE):
If I select "1 - ANSI" I get:
Build Library: ANSI
ERROR: file (INCLUDE\_ANSI.ch) not exist or failed copy
Press any key to continue . . .
If I select "2 - UNICODE" I get:
Build Library: UNICODE
ERROR: file (INCLUDE\_UNICODE.ch) not exist or failed copy
Both _ANSI.ch and _UNICODE.ch are definitely in C:\HMG.3.4.4\INCLUDE
Would someone please help me understand my problem here?
Thank you, Red2
Red2
Re: Err building HMG IDE
Post by Red2 »
Correction: I meant the HMG Debugger
Thanks, Red2
