MsgInfo with LINK ?
MsgInfo with LINK ?
i want to show a Message when "Component" are not installed
i also want to show a LINK to download "Component"
how can i display it :?:
i know i can use a LINK in RICHTEXT ...
Re: MsgInfo with LINK ?
AUGE_OHR wrote: Sat Jun 24, 2023 10:50 pm hi,
Hi Jimmy,
You will need a wrapper for the Vista TaskDialog() function.
There is the above posibility in MiniGUI with the following ShowMessage() function :arrow:
FUNCTION ShowMessage( cTitle, cMainMessage, cContent, cExpandedInfo, cFooter, nIcon, nFooterIcon )
   LOCAL aConfig := Array( TDC_CONFIG )
   LOCAL nButton, nRadioButton
   LOCAL lVerificationFlagChecked := .F.
   hb_default( @cTitle, "Vista TaskDialog" )
   hb_default( @cMainMessage, "" )
   hb_default( @cContent, "" )
   hb_default( @cExpandedInfo, "" )
   hb_default( @cFooter, "" )
   hb_default( @nIcon, TD_INFORMATION_ICON )
   hb_default( @nFooterIcon, 0 )
   aConfig[ TDC_TASKDIALOG_FLAGS ]        := TDF_ENABLE_HYPERLINKS
   aConfig[ TDC_COMMON_BUTTON_FLAGS ]     := TDCBF_OK_BUTTON
   aConfig[ TDC_HWND ]                    := GetActiveWindow()
   aConfig[ TDC_HINSTANCE ]               := GetInstance()
   aConfig[ TDC_MAINICON ]                := nIcon
   aConfig[ TDC_WINDOWTITLE ]             := cTitle
   aConfig[ TDC_MAININSTRUCTION ]         := cMainMessage
   IF !Empty( cContent )
      aConfig[ TDC_CONTENT ]              := cContent
   IF !Empty( cExpandedInfo )
      aConfig[ TDC_EXPANDEDINFORMATION ]  := cExpandedInfo
      aConfig[ TDC_EXPANDEDCONTROLTEXT ]  := "Hide details"
      aConfig[ TDC_COLLAPSEDCONTROLTEXT ] := "Show details"
   IF !Empty( cFooter )
      IF !Empty( nFooterIcon )
         aConfig[ TDC_FOOTERICON ]        := nFooterIcon
      aConfig[ TDC_FOOTER ]               := cFooter
   aConfig[ TDC_CALLBACK ]                := {|h,n,w,l| callback( h,n,w,l )}
   RETURN win_TaskDialogIndirect0( aConfig, @nButton, @nRadioButton, @lVerificationFlagChecked )
STATIC FUNCTION callback( hWnd, nNotification, wParam, lParam )
   LOCAL lResult := .F.
   To prevent the task dialog from closing, the application must return FALSE,
   otherwise the task dialog is closed
   LOCAL hResp := { 1=>"OK", 2=>"CANCEL", 3=>"ABORT", 4=>"RETRY", 5=>"IGNORE", 6=>"YES", 7=>"NO", 8=>"CLOSE" }
   SWITCH nNotification
   CASE TDN_BUTTON_CLICKED
      // wParam - an int that specifies the ID of the button or comand link that was selected
      IF hb_HPos( hResp, wParam ) != 0
         lResult := .T.
      EXIT
   CASE TDN_HYPERLINK_CLICKED
      ShellExecute( hWnd, "open", lParam, , , SW_SHOW )
   END SWITCH
   RETURN lResult
For example, the following call
ShowMessage( , 'This uses the "ShowMessage" function', ;
"Just use an additional parameter (optional) to add this extra text.", ;
"And another parameter for yet more text. And another parameter for the footer.", ;
'This is the footer with hyperlink <a href="www.hmgextended.com">MiniGUI Software Page</a>', , TD_INFORMATION_ICON )
will show a window like the one below:
Hope it is helpful. :idea:
JALMAG
DBs Used: DBF, MariaDB
Post by JALMAG »
Very nice!
Thanks
hi Grigory,
gfilatov wrote: Sun Jun 25, 2023 8:19 am You will need a wrapper for the Vista TaskDialog() function.
thx for Answer and Sample
as i say i want to display a URL for download
but the URL should be "clickable" like in RICHTEXT
