The big problem is when the table has many rows, how to show it and make it fast
I found data for countries and cities of the world, 250 countries and 94000 cities, I think it is good for example
Download, unzip, then build demo.prg
I know the example is simple, if you have time take a look and write a comment so it could be better
Form with paging
- dragancesu
Form with paging
- paging.zip
- (739.59 KiB) Downloaded 1343 times
Re: Form with paging
Hola Dragan :
yo use en mi POS (point of sale) la identificacion GS1 de cada pais para ubicar de que pais pertenece ese producto con el prefijo y asi poder mostrar su origen con un icono de la bandera del pais... nose como concatenar las cuidades a esos paises .
When the number or rows/records are huge, use VirtualGrid.
Os recomiendo este ejemplo, puede ayudar a muchos
- PRUEBA.zip
- (1.71 MiB) Downloaded 1280 times
Virtual GRID works with arrays or only with DBF?
I seldom work with DBF: always MySQL.
