QR Code (HMG_Zebra)
s57ua
QR Code (HMG_Zebra)
Post by s57ua »
can someone suggest how to implement ECI - Extended Channnel Interpretation codes (8859-2) in hbzebra (qrcode)?
Best regards, TIA
Mitja
Re: QR Code (HMG_Zebra)
From what I was able to find out, you need to add ECI indicator at the beginning of the string, for 8859-2 it is "\000004". So an example string should look something like "\000004Zażółć gęślą jaźń". It should be noted that not all qr code readers correctly interpret ECI indicators.
Note that the official HMG function for generating QR codes has a bug. Here is the fix: http://hmgforum.com/viewtopic.php?p=534 ... cbb#p53474
Red2
Post by Red2 »
Thank you very much EDK for the link.
I am now able create QR files using HMG.
QUESTION:
Does anyone know if there is also HMG program code to read a QR file and return its text contents?
Spence
Red2 wrote: Tue Mar 28, 2023 2:32 pm QUESTION:
have a look into MiniGUI Extended Version
c:\minigui\Samples\Advanced\QrDecode\
Red2
Post by Red2 »
Thank you Jimmy, I'll have a look.
Red2
