Writing HMG code with "you.com"
Hello friends:
The translation is from Google
I present to https://you.com/ that through >_ Code or in the Chat of its menu, you can generate
HMG code. by indicating a small indication for you to write code, example:
Mustafa =>
create a code in HMG with main window type DEFINE WINDOW Form_1 ,
with a query GRID and a dbf database
fields "Name" and "Age" if the database does not exist, you have to create it
also create an "exit" button with your code
You.com=>
Here I provide you with an example of HMG code that meets the requirements you request.
The code creates a main window with a query GRID and a dbf with
"Name" and "Age" fields. It also includes an "Exit" button with its corresponding code:
and I create this code
FUNCTION Main()
   // Crear base de datos dbf
   IF ( ! File( "datos.dbf" ) )
      USE datos NEW
      datos->( dbStruct( { "Name C(30)", "Age N(3)" } ) )
   // Crear ventana principal
   DEFINE WINDOW Form_1 ;
      WIDTH 640 HEIGHT 480 ;
      TITLE "Consulta de Datos" ;
      MAIN
      // Crear GRID de consulta
      DEFINE GRID Grid_1
         ROW    40
         COL    40
         WIDTH  550
         HEIGHT 300
         HEADERS { "Nombre", "Edad" }
         WIDTHS  { 400, 100 }
         FIELDS  { "Name", "Age" }
         FONT   { "Tahoma",10,0 }
         VALUE  {||}
         PICTURES {||}
         ON ROW DOUBLECLICK SELECT (*Grid_1).Value
      END GRID
      // Crear botón "Exit" con su código correspondiente
      DEFINE BUTTON Button_1
         ROW   350
         COL   270
         CAPTION "Exit"
         WIDTH 100
         ACTION Salir
      END BUTTON
   ACTIVATE WINDOW Form_1
// Código del botón "Exit"
PROCEDURE Salir()
   CLOSE DATABASES
   QUIT
you.com =>
Keep in mind that this is just an example and you will need to adapt it to your specific needs.
There may also be bugs or special cases that you need to handle.
Mustafa-> in the GRID ROWSOURCE "Data" is missing
you.com=>
You are right, by adding the line ROWSOURCE "Data" when defining the GRID, the GRID is bound
with the database and displays the data from the database in window [1].
Here I show you what the GRID definition should look like:
DEFINE GRID Grid_1
   ROW         40
   COL         40
   WIDTH       550
   HEIGHT      300
   WIDTHS      { 400, 100 }
   VALUE       {||}
   PICTURES    {||}
   ROWSOURCE   "Datos"
END GRID
With the ROWSOURCE "Data" line, the GRID will be associated with the "Data" table of the dbf file,
and it will display the records in the window.
I hope this resolves your query. If you have any other questions, don't hesitate to ask.
I only had to correct a little the code provided by You.com and it's OK!
Mustafa=> Fixed Code
FUNCTION Main()
       Crea_Base()
       USE Datos NEW
       Datos->(dbStruct( { "Name C(30)", "Age N(3)" } ))
      MAIN
  DEFINE GRID Grid_1
     ROW         40
     COL         40
     WIDTH       550
     HEIGHT      300
     HEADERS     { "Name", "Age" }
     WIDTHS      { 400, 100 }
     ROWSOURCE   "Datos"
     COLUMNFIELDS { "Name", "Age" }
     FONTNAME     { "Tahoma",10,0 }
  END GRID
         ROW   350
         COL   270
         CAPTION "Exit"
         WIDTH 100
         ACTION Salir()
      END BUTTON
   CENTER WINDOW Form_1
PROCEDURE Salir()
   CLOSE DATABASES
   QUIT
 FUNCTION Crea_Base()
 LOCAL aStruct := { ;
  { "NAME"   , "C", 30, 0 }, ;
  { "AGE"    , "N", 03, 0 }  ;
  DbCreate( "Datos", aStruct, .T. )
  USE datos NEW
  DbAppend()
  REPLACE NAME WITH "Peter"
  REPLACE AGE WITH   20
  DbAppend()
  REPLACE NAME WITH "Carolyn"
  REPLACE AGE WITH  15
  dbcloseall()
 USE datos NEW
Saludos , Regards , Salam
Re: Writing HMG code with "you.com"
Thanks Mustafa !
Red2
Post by Red2 »
Very informative.
Thank you!
