OLE
trmpluym
OLE
Post by trmpluym »
Dear friends,
I like to get information from an Active Directory using the OLE ADSystemInfo.
In VBS this works easy:
https://ss64.com/vb/syntax-userinfo.html
In Harbour I get here:
LOCAL oAD, oUser
oAD := CreateObject( "ADSystemInfo" )
oUser := oAD:UserName
MsgDebug (oAD:UserName)
But now the next part: GETOBJECT()
In Foxpro this function existed:
https://harbour.wiki/index.asp?page=Sho ... &InFrame=Y
I found a feature request the also make this feature available:
https://www.mail-archive.com/harbour@ha ... 13937.html
I like to achieve:
*  Replace "DomainName" with the domain name, and "UserLoginID"
*  with the login ID of the user you are looking up.
oUser = GetObject("WinNT://DomainName/UserLoginID,user")
? oUser.FullName
Somebody knows ?
Theo
Re: OLE
Por lo que he leído, necesitas un entorno de WinServer xxxx.
Quien lo tenga o lo use, te podría decir.
From what I've read, you need a WinServer xxxx environment.
Whoever has or uses it could tell you.
