Restore Grid Widths !
Claudio Ricardo
DBs Used: DBF, MySQL, MariaDB
Post by Claudio Ricardo »
Hi All !
I can autoadjust grid columns widths with " Control and + " from keyboard (Tip posted here)
and now i need restore at the values set in control definition... It is possible without redefine control ? How ?
This grid is in Main form... I try code below but don't work:
Function Modulo_Reportes_Button_Widths_Action
Local aWidths := {70,70,70,70,200,90,90,70,70,90,90,90,90,200,40,40,40}   // <- original widths
	SetProperty ("Main", "Grid_Ventas", "Widths", aWidths)
	// Main.Grid_Ventas.Widths := aWidths
	// I try with above oop syntax but when compile say: Error E0030 Syntax error "syntax error at '.' "
Thanks in advance !!!
Re: Restore Grid Widths !
you can use
   nWide := LISTVIEW_GETCOLUMNWIDTH( hGrid, mCol - 1 )
and
   LISTVIEW_SETCOLUMNWIDTH( hGrid, mCol - 1, nWide )
for nWide == -1 you get "optimal" Size for a Column
Claudio Ricardo
Wonderful Jimmy !!!
Now I can toggle with button, between optimal and pre set widths without focus in grid !!!
Local hGrid := GetControlHandle ( "Grid_Ventas", "Main" )
	If LISTVIEW_GETCOLUMNWIDTH ( hGrid, HMG_Len (aWidths) - 1 ) < Atail (aWidths)
		For i := 1 To HMG_Len (aWidths)
			LISTVIEW_SETCOLUMNWIDTH ( hGrid, i - 1, aWidths [i] )
		Next
	Else
			LISTVIEW_SETCOLUMNWIDTH ( hGrid, i - 1, -1 )
		Next
	EndIf
The last column is a one letter field, for this i use at refference...
Thank you very much for helping me quickly and for teaching me two functions I didn't know !!!!
