HMG Extended Edition version 22.12 is published
Hi Friends,
Edition.
A setup of the ANSI build 22.12 for Borland C++ 5.8.2 is published at
the following URL:
There is also an extra donationware Minigui package built for the freeware
Embarcadero C++ 10.2 ‘Tokyo’ 32-bit compiler (which is included in the above
package for your convenience).
Whatsnew:
2022/11/29: HMG Extended Edition version 22.12.
* Fixed: Memory leak in CHECKLABEL related to bitmaps that existed since
the first implementation of this control.
Contributed by Grigory Filatov <gfilatov@gmail.com>
* Enhanced: SWITCHER control supports displaying the corresponding image
for disabled/enabled state at runtime.
You can set/get this property with:
- function syntax:
SetProperty ( Form, Switcher, 'Enabled', .T.|.F. )
GetProperty ( Form, Switcher, 'Enabled' )
- pseudo-OOP syntax:
Form.Switcher.Enabled := .T.|.F.
Form.Switcher.Enabled --> lStatus
It was a postponed modification.
(see demo in folder \samples\Basic\CheckLabel_3)
* Updated: Further replacement of return values in the kernel C-code
with using the macros from the header file mgdefs.h.
Unnecessary variables have also been removed in some places
in the C code.
* Updated: Adaptation FiveWin Class TSBrowse 9.0 in HMG:
- Fixed: the KeyChar() method crashed when defining TBrowse
without any columns.
Bug was reported by Luis Carlos Bolanhos.
(see demo in folder \Utils\mgDBU)
* Updated: HbSQLite3 library:
- update for using SQLITE3 version 3.40.0 (from 3.40.0dev).
* Updated: Shell32 library:
- updated for the recent changes in the Minigui core.
(see demo in folder \samples\Basic\Shell32)
* New: 'GRID Dynamic Color Test' sample.
Based upon a contribution of HMG user Edward.
Adapted for Minigui Extended by Grigory Filatov
(see demo6.prg in folder \samples\Basic\Grid_Test)
* Updated: 'Clipboard Tests' sample:
- added getting a bitmap image from the clipboard and placing it
on a tab.
(see in folder \samples\Basic\CLIPBOARD)
* Updated: 'Tree Menu' sample by Bicahi Esgici:
- updated procedure ExpandAll() for recursive action.
(see in folder \samples\Basic\TreeMenu)
Upgrading to this build is highly recommended.
May the Holiday Season bring only happiness and joy to you and your families.
Greetings,
[MiniGUI Team]
Re: HMG Extended Edition version 22.12 is published
Thanks Grigory and for you and your family also happiness and joy!
quartz565
Post by quartz565 »
Thank you Grigory !
Nikos.
os: Windows Server 2019 - 64
I've uploaded the updated setup of the build 22.12 for Borland C++ 5.8.2 at
Whatsnew:
2022/12/12: HMG Extended Edition version 22.12 (Update 1).
* Fixed: Font color of CheckBox and Frame controls is ignored when
they are defined on the Tab page.
The issue was reported by Pete D.
* Enhanced: The GetBox control supports optional 'AUTOUPDATE' clause
which only works with the FIELD clause. This clause enables
automatic recording of the entered value in the DBF field.
Sample code:
@ 10, 10 GETBOX GetBox1 FIELD Test->CODE AUTOUPDATE
This should be considered as an experimental feature.
Requested by Slavko Ivanovic.
* Modified: ButtonEx: using the definitions from C header uxtheme.h
instead of local implementation.
* Updated: Added new global macros for some parameters in the header
file mgdefs.h.
* Updated: 'Bos Taurus' Graphics Library:
- revised all code for optimization similar to Minigui core.
(see source in folder \Source\BosTaurus)
- re-fixed the KeyChar() method after the previous bug fix
(introduced in build 22.12).
Bug was reported by Fischer Zsolt.
* Updated: Harbour Compiler 3.2.0dev (SVN 2022-11-25 18:14).
(look at ReadMe.txt in folder \harbour)
* Updated: 'Enum Processes' sample by Claudio Soto:
- updated with the latest changes in the Minigui core.
(see in folder \samples\Advanced\EnumProcesses)
* Updated: 'Set a default icon to a standard dialog box' sample:
(see in folder \samples\Advanced\SetDialogBoxIcon)
Upgrading to this update is recommended.
May the magic and the wonder of the Holiday season be with you
throughout the coming year.
[MiniGUI Team]
Hi Friends,
Whatsnew:
2022/12/21: HMG Extended Edition version 22.12 (Update 2).
* Enhanced: The ComboBox control supports the 'FontColor' and 'BackColor'
properties in the THEMED Operating Systems.
It was a postponed user's request.
(see demo in folder \samples\Basic\Color)
* Modified: Adaptation of MiniGUI core is finished for compatibility with
Borland/Embarcadero C++ 7.40 64-bit compiler.
Notice that an additional XMATH system library is required for
proper linking of the application. But this library is not in
the official Embarcadero distribution.
* Updated: Uncrustify formatting is applied to all C core code with
configuration file hb-uncrustify.cfg from Harbour fork 3.4.0.
* Updated: WinReport library (see source in folder \Source\WinReport):
- fixed wrong interpretation of Landscape command with MiniPrint.
Contributed by Pierpaolo Martinello <pier.martinello[at]alice.it>
(see demo in folder \samples\Advanced\REPORT_INTERPRETER)
* Updated: 'Tetris game' sample by Claudio Soto:
- minor modifications in the procedure CreateVars().
(see in folder \samples\Applications\HMG_Tetris)
Upgrading to this update is optional.
May your home be filled with warmth and wonder this Holiday season.
[MiniGUI Team]
