VPN or hide IP
VPN or hide IP
Hello Everyone, My internet Knowledge is minimal.
Is it possible to hide my IP from outer world.
Like create my own VPN or ?
All The Best,
Franco
Canada
Franco
Canada
- dragancesu
Re: VPN or hide IP
What do you want?
- AUGE_OHR
Re: VPN or hide IP
hi Franco,
"LOCAL" IP like 192.168.xxx.xxx are difference from "Online" IP which you get "dynamic" from Provider
using VPN it will route by different Server / Provider so only "last" Provider IP will be "known"
- vagblad
- DBs Used: MySQL,DBF
Re: VPN or hide IP
Franco the vpn subject is highly technical as you might understand.
If you just want a way to encrypt your data it's pretty easy to set up . You still need to rent a cloud server from a datacenter.(Azure,Amazon etc) There are free options but with limited bandwidth and hours restrictions and such.
Then you will setup your route through this https://github.com/trailofbits/algo. You have to download Algo and set it up. After that you need to setup your devices to connect through your vpn.
A lot of drawbacks in my opinion to that. If you actually want proper privacy you have to "destroy" your private server on the cloud and then make a new one. The IP from which you will be connecting to the outer world will always be the same so essentially it can become a target at some point. Also if you want to use a VPN to bypass certain products' restrictions(for example Netflix) you won't be able to do it.
To summarize and in my personal opinion if you seriously need a vpn you should sign up for a proper VPN service. They are not that expensive these days and they also offer "home" packages which are even cheaper.
Vagelis Prodromidis
Re: VPN or hide IP
Re: VPN or hide IP
Franco : si quiere navegar de forma segura en mi caso uso Avast Antivirus con el agregado de Avast Antitrack y VPN lo que me protege de sitios inseguros y rastreosde los mismos y en VPN podeer elegir que pais enmascara mi direccion ip...
como no sabemos para que quierer usar el VPN esta es mi ejemplo repuesta
