HMG 22.11 final build is ready
Hi Friends,
Edition.
A setup of the ANSI build 22.11 for Borland C++ 5.8.2 is published at
the following URL:
There is also an extra donationware Minigui package built for the freeware
Embarcadero C++ 10.2 ‘Tokyo’ 32-bit compiler (which is included in the above
package for your convenience).
Whatsnew:
2022/11/15: HMG Extended Edition version 22.11.
* Fixed: Correction of style C-type from int to DWORD in the Minigui core
according to the WinAPI definition.
Contributed by Grigory Filatov <gfilatov@gmail.com>
* Updated: C-code cleaning for unneeded variables when defining controls
and windows in the Minigui core.
* Updated: HbCurl library:
- added HB_CURLOPT_MAXLIFETIME_CONN to setup max lifetime;
- added HB_CURLOPT_DEBUGBLOCK to setup a block for debug.
Contributed by Antonino Perricone
(see in folder \Harbour\Lib)
* Updated: HbSQLite3 library:
- update for using SQLITE3 version 3.40.0dev (from 3.39.4).
* Updated: Harbour Compiler 3.2.0dev (SVN 2022-11-11 21:15).
(look at ReadMe.txt in folder \harbour)
* Updated: 'Desktop Windows Version Market Share Worldwide' sample:
- updated the data for October 2022.
(see demo.prg in folder \samples\Basic\GraphPrint)
* Updated: 'MiniGUI DataBase Utility' sample:
- fixed setting of tags in TBrowse with using :uLastTag variable;
- others minor corrections regarding tags.
(see in folder \Utils\mgDBU)
There are also minor fixes in the MiniPrint2 and TSBrowse libraries.
Greetings,
[MiniGUI Team]
P.S.
All donors will receive 32- and/or 64-bit Minigui packages
based on the latest MinGW compiler as a gift.
Thanks a lot for your attention.
Anand
Re: HMG 22.11 final build is ready
Post by Anand »
Thanks for the update.
Anand
Thanks Grigory !
