Another Array-to-Text routine
HGAutomator
Post by HGAutomator »
Some random searching led to this gem, from 1994-1995. It generates a text string from an array, but in a different form, from http://hmgforum.com/viewtopic.php?f=9&t=7326, and from other Array-To-Text routines.
It might be useful, to some of you.
Note: This was released into the public domain on 11/3/1995
                 The Klipper Library, for CA-Clipper 5.x
        Copyright (c), 1994, Wallace Information Systems Engineering
FUNCTION:
k_Array2Str(xArray) --> cString
PARAMETERS:
xArray: Array containing elements of types C, N, D, L, or NIL
SHORT:
Convert an array to a single character string.
DESCRIPTION:
k_Array2Str() stores and array (either single or multiple dimension) in
a string formatted such that k_Str2Array() can recreate it.
It can be used in conjunction with Var2File() to store arrays (again,
single or multiple dimension) to disk files.
The resulting string is only useful and meaningful to k_Str2Array() so any
use of it without this other function is highly suspect.
NOTE:
k_Array2Str() will ignore any element that is not character, numeric,
date, logical or another array of the same!!
Code blocks are right out!  Same for Memos and "objects."
Any attempt to use k_Array2Str() with these unsupported data types will
render unpredictable results.
EXAMPLE:
t = {'a','b',{'1','2','3'},'d')
astr = k_Array2Str(t)
Result: aStr is a string containing the entire array.  It can now be restored
to an array with "t = k_Str2Array(astr)", or it can be written to a disk file
via k_Var2File(astr).
To completely store and restore an array to and from disk:
// going in...
aArray = {'a','b',{'1','2','3'},'d')
aStrArray = k_Array2Str(aArray)
k_Var2File(aStrArray,"FILE.EXT")
// coming out...
t = {}
aStrArray = k_File2Var("FILE.EXT")
t = k_Str2Array(aStrArray)
// or, simplified:
aArray1 = {'a','b',{'1','2','3'},'d')
k_Var2File(k_Array2Str(aArray),"FILE.EXT")
aArray2 = k_File2Var("FILE.EXT")
// or, a one-liner:
aArray2 = k_Str2Array(k_File2Var(k_Var2File(k_Array2Str(aArray1),"FILE.EXT")))
which essentially copies aArray1 to aArray2 via a disk file.
This is possible because k_Var2File() returns the name of the file the
variable was stored in.  (See k_Var2File()).
// #include "klipper.ch"
#include "fileio.ch"
FUNCTION k_Array2Str(xArray)
LOCAL    cRetVal := ""
LOCAL    i
for i = 1 to len(xArray)
    do case
        case xArray[i] == NIL
            cRetVal += LF+'_XX'
        case valtype(xArray[i]) == 'C'
            cRetVal += LF+'_XC'+xArray[i]
        case valtype(xArray[i]) == 'D'
            cRetVal += LF+'_XD'+dtoc(xArray[i])
        case valtype(xArray[i]) == 'N'
            cRetVal += LF+'_XN'+ltrim(str(xArray[i]))
        case valtype(xArray[i]) == 'L'
            cRetVal += LF+'_XL'+iif(xArray[i],'T','F')
        case valtype(xArray[i]) == 'A'
            cRetVal += LF+'_XA'+ltrim(str(len(xArray[i])))+k_Array2Str(xArray[i])
    endcase
next
RETURN(cRetVal)
Re: Another Array-to-Text routine
Hi Dwayne,
You may take a look at the internal core functions of Minigui below: :arrow:
- AToC( aArray ),
- CToA( cArray ),
which are used to similarly convert an array to a string and vice versa when working with INI files. :idea:
tonton2
Post by tonton2 »
gfilatov wrote: Thu Oct 20, 2022 11:55 am Hi Dwayne,
- AToC( aArray ),
- CToA( cArray ),
Bonsoir Grigory
Y a t il une une fonction AToC( aArray ) en HMG SVP merci ?
Is there the same "AToC( aArray )" in HMG Thanks ?
L'Algerie vous salut
Y.TABET
tonton2 wrote: Tue Jan 24, 2023 9:45 pm
- AToC( aArray ),
- CToA( cArray ),
Bonsoir Grigory
Bonsoir
Yes, it is.
It exists in the library libini.a in the folder \hmg.3.4.4\lib :idea:
