Add / Remove FILTER from existing DBFILTER()
guess i have use
SET FILTER TO FIELD->AAA = "ABC" .AND. FIELD->BBB = "EFG"
and i want to "add" more ... how under HMG :?:
also how to "remove" Part of DBFOLTER() :?:
Re: Add / Remove FILTER from existing DBFILTER()
If you want to add something new:
cNewFilter := dbFilter() + ".and." + cExpression
Set Filter to
set filter to cNewFilter
you can use dbClearFilter() instead of SET FILTER TO
for changing something, the best way is removing defined filter and defining it again, in my opinion.
hi Mol,
mol wrote: Wed Aug 10, 2022 6:49 pm
Set Filter to
hm ... DBFLTER() return String not Codebock as i expect
you are right, it is (much) more work to "remove" a Part than create a New FILTER
Jimmy,
Maybe this works:
cNewFilter := dbFilter() + ".and." + &cExpression
or this
cNewFilter := dbFilter() + .and. + &cExpression
If you have filter expression from dbFilter(), you can easy change it codeblock:
cNewFilter := "{||" +  dbFilter() +".and." + cExpresion +"}"
bNewFilter := &cNewFilter
