Change grid field widths in while in grid.
franco
Post by franco »
I have a grid that field width is 40 chars. In my grid I only have room for first 20 so field width is 20.
When I hit enter or dblclick in grid I would like to change the width Of the column I am on so I can see it all and edit it all.
Define Grid Grid_1
			WIDTHS {140,140,140,100,100,100}
		     	ALLOWEDIT .T.
			CELLNAVIGATION .T.
			ON CHANGE ACTION MY2()
ON KEY RETURN ACTION MY1()
THE FOLLOWING DOES NOT WORK
Function My1
	local avcell := form_1.grid_1.value
	if avcell[2] = 2
		Form_1.Grid_1. WIDTHS := {140,280,140,100,100,100}
Function My2
	//  do saves and so on. Then reset field widths
	if avcell[2] = 2
		Form_1.Grid_1. WIDTHS := {140,140,140,100,100,100}
Thanks in advance.
All The Best,
Franco
Canada
Red2
Re: Change grid field widths in while in grid.
Post by Red2 »
Hi Franco,
I have code I use to resize a form's Width and Height and it's controls.
(I do not change the font),
Specifically, this code adjusts a form's Grid and its columns (Width and Height)
to fit the new form dimensions.
If your are interested I can post the .PRG as an attachment.
You should be able to adapt it to
1) widen the column clicked on and
2) reset any previously clicked to the normal width.
Please let me know if you are interested.
Red2
franco
Post by franco »
Thanks for response Red2,
This sounds like what I need.
Your help would be greatly appreciated.
All The Best,
Franco
Canada
Red2
Post by Red2 »
Hi Franco,
This .PRG was tailored to my form's needs.
Thus only only certain controls are currently supported.
1) In the form's INIT default form values are stored, PROCEDURE DoResizeInit( p_cFormName )
2) These values are then available during the Resize Event, PROCEDURE AutoAdjust( p_cFormName )]
You will need code to determine which column is clicked.
I hope that this is helpful. Please let me know if you have any questions or improvements to my code.
Red2
Resize.7z
(5.06 KiB) Downloaded 122 times
franco
Post by franco »
Red2,
Thats a lot of code to translate.
I know form name and grid name and column and row.
local avcell , ro, col
ro := avcell[1]
co := avcell[2]
SO.......... avcell[1] = row avcell[2] = column.
In your code is there a way to set width of only ro ,co to its width * 2.
then later set same back to width /2
I think it only needs one line of code for each.
I had thought of just having a second grid with just one column for edit but still can not see cell value when in first grid.
All The Best,
Franco
Canada
Red2
Post by Red2 »
Hi Franco,
Yes, the .PRG's code includes a lot of stuff.
I will unfortunately be distracted with non-computer things for the next week or two.
Given that your program knows the default (unexpanded) Grid column
widths I think that I would approach your issue as follows.
1) Before expanding a column Iterate through the grid's columns.
For any non-default column width, restore that column's original width.
2) Or, before your program expands a column first save that column number to a variable.
Before expanding a column, first check that variable and restore the previously expanded column's width.
These are my quick thoughts. I'd be glad to help in greater detail but I'll be unavailable for a while.
Until then, please let me know if this helps or if you have any further questions.
Red2
franco
Post by franco »
Thanks Red2
I found a way that seems to work ok seeing my fields are all character.
By hitting enter or dblclick, I can see the total field value and can view or change.
This seems to work fine for now.
         WINDOW
                ON KEY RETURN  ACTION MY()
                ON DBLCLICK MY()
		END GRID
Function my()
local ac := form_1.grid_1.value, fl2 := " ", ch
if ac[2] = 1
	return
if ac[2] = 2
	fl2 := 'first'
if ac[2] = 3
	fl2 := 'last'
go form_1.grid_1.recno
ch := fl2
ch := upper(inputbox('Enter Appointment Data', ,&ch))
if msgyesno( 'Save Appointment Changes')
	if rlock()
		replace &fl2 with ch
		unlock
	Form_1.Grid_1.refresh()
Form_1.Grid_1.Value := ac
All The Best,
Franco
Canada
hi.
Set Focus to GRID and press
Ctrl + "+" ( Plus on Numpad )
franco
Post by franco »
Hey.
That something. How would we reset back to original.
All The Best,
Franco
Canada
franco wrote: Sun Jul 17, 2022 4:16 pm How would we reset back to original.
i guess you have Array of Width -> aCol
   hGrid := GetControlHandle( "Grid_1", "Win_1" )
   jMax := LEN( aCol )
   j := 1
   FOR j := 1 TO jMax
      nWide := aCol[ j ]
      LISTVIEW_SETCOLUMNWIDTH( hGrid, j - 1, nWide ) // Column Zero = 0 based
p.s. if nWide == -1 than it will "optimize" Column
