how to use different Font Size in RICHEDITBOX ?
i want to use different Font Size in RICHEDITBOX , how ?
   DEFINE WINDOW Helpfile ;
      ON INIT DoInit2( ThisWindow.Name, lImage, cMemo ) ;
      DEFINE RICHEDITBOX Edit_1
         VALUE ""
         FONTNAME "Arial"
         FONTSIZE 12
         READONLY .T.
STATIC PROCEDURE DoInit2( cForm, lImage, cMemo )
LOCAL iMax := LEN( aTip )
*   IF EMPTY( iMax )
*     SetProperty( cForm, "Edit_1", "FONTSIZE", 48 )
      Helpfile.Edit_1.FontSize := 48
*   ENDIF
   SetProperty( cForm, "Edit_1", "VALUE", cMemo )
but Font Size does not change ... :(
what i´m doing wrong :?:
Re: how to use different Font Size in RICHEDITBOX ?
AUGE_OHR wrote: Fri Jun 17, 2022 10:17 am hi,
Hi Jimmy,
You can use two ways for this need:
1) low-level formatting of the RTF-text via his internal RTF structure.
Example:
LOCA cDBAbout := ;
"{\rtf1\ansi\ansicpg1254\deff0\deflang1055\deflangfe1055{\fonttbl{\f0\fswiss\fprq2\" + ;
"fcharset162 Verdana;}{\f1\fswiss\fprq2\fcharset0 Verdana;}}{\colortbl;\red0\green0\blue255;}"+;
"{\*\generator Msftedit 5.41.15.1507;}\viewkind4\uc1\pard\nowidctlpar\ri-1418\f0\fs18\par"+;
" HMG Data Base Assistant v." + ExeFD2Vrs() + "\par"+;
"\pard\nowidctlpar\ri-1748\qj\fs16\par \'a9 \cf1 esgici@gmail.com\par"+;
"\cf0\b\par \b0 DBA\b \b0 is an imitative work to the \'a9 \b dBASE III'\b0 s Assistant.\par"+;
"\par It may be an easy tool for people who are familiar to \par"+;
" this \b base\b0 architecture of the whole xBase family. \par"+;
"\par Many thanks to : \par\par"+;
" \b Antonio Linares \b0 ( Initiator of \'a9 \b Harbour\b0 ) and\par"+;
" \i Le Roy \b\i0 Roberto Lopez \b0 ( Initiator of \'a9 \b MiniGUI \b0 ).\par"+;
"\par Without this two big men and their volunteer coworkers, \par"+;
"\b \b0 DBA ( and many others of course) couldn't be exist.\par"+;
"\par\pard\sb100\sa100 \cf1\lang1033\f1 https://harbour.github.io\cf0\lang1055\f0\par"+;
"\pard\nowidctlpar\ri-1748\qj\cf1 http://harbourminigui.googlepages.com\cf0\par}"
DEFINE RICHEDITBOX rtfAbout
ROW 0
COL 0
WIDTH frmAbout.WIDTH - 4
HEIGHT frmAbout.HEIGHT - 24
VALUE cDBAbout
READONLY .T.
END RICHEDITBOX // rtfAbout
2) using the extra class RichText via the predefined commands (included in the Minigui Advanced samples).
Example:
STATIC FUNCTION CoverPage( oRTF )
* Description:  Generate a cover page.
* Arguments:
* Return:
* Date       Developer   Comments
* 01/28/97   TRM         Creation
LOCAL i
LOCAL aTitle[3]
LOCAL aBullet[5]
//	First, load some text...
aTitle[1] := "RichText() Sample Report Summary"
aTitle[2] := "NOTE: This report includes an automated table of contents. " + ;
				"If you are using MS-Word, you can create the table of contents " + ;
				"via the Insert\Indexes and Tables... option. Be sure to tell " + ;
				'MS-Word to generate the table from "table entries", rather ' + ;
				'than from "styles".'
aBullet[1] := "This report is a demonstration of some of the capabilities " + ;
			"of the RichText() class for Clipper & Fivewin, Version 1.0, written " + ;
			"by Tom Marchione.  This is the free version, which contains a " + ;
			"basic feature set (please review the README file for certain " + ;
			"minor usage restrictions). If you have any comments or questions, " + ;
			"feel free to send an E-Mail to tmarchione@compuserve.com."
aBullet[2] := "RichText() lets you generate reports to RTF files, like this " + ;
			"one.  RTF files can be read by most word processors, so this " + ;
			"is a way to move fully-formatted information into word processor " + ;
			"format, without lots of extra spaces and carriage returns.  " + ;
			"The class can form the basis of a true database publishing system."
aBullet[3] := "RichText() is not meant to be a front-line report engine in " + ;
			"its current form, in the sense that database programmers " + ;
			"expect report generators to have certain standard features.  " + ;
			"Nevertheless, it can be very useful for meeting specialized, " + ;
			"custom reporting requirements, particularly if you need to edit or " + ;
			"manipulate the output."
aBullet[4] := "In its current form, the system is fairly quirky.  " + ;
			"The good news is that, generally, you can get exactly what you " + ;
			"want in one or two code iterations.  I plan to address " + ;
			"various usability issues in future versions."
aBullet[5] := "The pages that follow contain some examples of the types of " + ;
			"things that can be done with RichText().  Remember, RichText() " + ;
			"is designed to link to a word processor, so its capabilities " + ;
			"focus on standard word processing features, rather than the " + ;
			"kinds of things that are important in a standard report " + ;
			"generator.  Hope you find it useful!"
// Write the title lines
NEW PARAGRAPH oRTF TEXT aTitle[1] ;
	FONTNUMBER 1 ;
	FONTSIZE 18 ;
	APPEARANCE BOLD_ON ;
	ALIGN CENTER ;
	SETDEFAULT ;
	TOCLEVEL 1  // 10/24/97 -- mark this for the Table of Contents.
NEW PARAGRAPH oRTF TEXT ""
NEW PARAGRAPH oRTF TEXT aTitle[2] ;
	FONTSIZE 10 ;
	APPEARANCE BOLD_OFF + ITALIC_ON ;
	ALIGN LEFT ;
	INDENT -.5 ;
	RIGHTINDENT -.5
NEW PARAGRAPH oRTF TEXT "" ;
	APPEARANCE BOLD_OFF + ITALIC_OFF ;
	SETDEFAULT
// Write the bullet items
FOR i := 1 TO LEN( aBullet )
	NEW PARAGRAPH oRTF TEXT aBullet[i] ;
		FONTNUMBER 2 ;
		FONTSIZE 11 ;
		ALIGN LEFT ;
		INDENT .25 ;
		FIRSTINDENT -.25 ;
		BULLETED ;
		SPACEBEFORE .4 ;
		SETDEFAULT
NEW PARAGRAPH oRTF TEXT "" SETDEFAULT
************************  END OF CoverPage()  ***********************
I've attached the result output RTF-file for your review. :arrow:
RTFDEMO.ZIP
(3.1 KiB) Downloaded 65 times
hi Grigory,
thx for Help.
have found out that i have to "Select" Part which i want to "modify"
   IF EMPTY( iMax )
      DoMethod( cForm, "Edit_1", "SelectAll" )
      SetProperty( cForm, "Edit_1", "FONTSIZE", 36 )
      DoMethod( cForm, "Edit_1", "UnSelectAll")
here i use "SelectAll" but normal it need "SelectRange" when just want 1 Word to "modify"
