Print .rmg file to pdf
franco
Post by franco »
I am trying to send a rmg report directly to a pdf file and can not get to work.
#include "hmg_hpdf.ch"
declare window Main
Function main_button_1_action
Local mna := getcurrentfolder()+"TRYPDF.PDF"
select printer pdf mna
	Use Test
	LOAD REPORT Test
** original works ***	EXECUTE REPORT Test PREVIEW SELECTPRINTER
        EXECUTE REPORT Test   PRINTERMNA             // THIS DOES NOT WORK
	Use
Thanks in advance
All The Best,
Franco
Canada
Re: Print .rmg file to pdf
franco wrote: Wed Jun 01, 2022 6:06 pm I am trying to send a rmg report directly to a pdf file and can not get to work.
declare window Main
	Use Test
	LOAD REPORT Test
	Use
Thanks in advance
REPORT EXECUTION
Function:
ExecuteReport ( <cReportName> , <lPrintPreview> , <lSelectPrinter> , [ <cOutputFile> ] )
Command:
EXECUTE REPORT <ReportName> [ PREVIEW ] [ PRINTERSELECT ] [ FILE <cFile> ] // cFile = mna
PDF Output:
- If <cOutputFile> with 'pdf' extension is specified, a PDF file with report
content will be generated. <lPrintPreview> and <lSelectPrinter> parameters
will be ignored).
- The following limitations applies when report is redirected to a PDF file:
- Only .jpg image files are allowed.
- When 'Underline' property is .t., color property is ignored (assumed black) for expressions.
- The following fonts are supported (all other are assumed as 'Times'):
- Times - Helvetica - Courier
franco
Post by franco »
Can not get to work. I may not quite understand your suggestions.
Could you add the correct code to my sample,
Thanks Franco.
All The Best,
Franco
Canada
En teoría, así debería de funcionar...
In theory, this is how it should work...
Function MAIN
@ <nRow> ,<nCol> BUTTON <ControlName> CAPTION <cCaption> ......     ACTION    main_button_1_action()
	Use Test
	LOAD REPORT Test
        EXECUTE REPORT Test  FILE mna
	Use
franco
Post by franco »
Thanks Andy works perfect, just what I needed and so simple.
Franco
All The Best,
Franco
Canada
