pCode DLL Sample
pCode DLL Sample
i try to run Code from this Sample
https://harbour.wiki/index.asp?page=Pub ... 8267913849
i have copy Code into DllCode.PRG
/*** dllcode.prg ***/
DYNAMIC QOUT, PROCNAME
// added to inform compiler and linker that
// references to above functions have to be
// resolved dynamically at runtime
proc MY_PROC()
? PROCNAME() + ": hello !!!"
return
init proc start
? "INIT PROC", PROCNAME()
return
exit proc end
? "EXIT PROC", PROCNAME()
return
and run
 hbmk2 -shared -strip -hbdyn dllcode.prg -n -w -es2
but i get Error
R:/Temp/hbmk_vujesp.dir/dllcode.o:dllcode.c:(.text+0x14): undefined reference to `hb_vmExecute'
R:/Temp/hbmk_vujesp.dir/dllcode.o:dllcode.c:(.text+0x34): undefined reference to `hb_vmExecute'
R:/Temp/hbmk_vujesp.dir/dllcode.o:dllcode.c:(.text+0x54): undefined reference to `hb_vmExecute'
R:/Temp/hbmk_vujesp.dir/dllcode.o:dllcode.c:(.text.startup+0x2c): undefined reference to `hb_vmProcessSymbols'
so what do i miss :?:
did someone have a working Sample, need help
Re: pCode DLL Sample
AUGE_OHR wrote: Mon May 30, 2022 9:53 am hi,
Hi Jimmy,
Please take a look for a working sample along with all needed binaries in the attached archive. :arrow:
pcodedll.zip
(2.41 MiB) Downloaded 167 times
hi Georgy,
Thx for Sample, it work great !
Question : what is libharbour-32.a for, it is not need in Sample
is a possible to create a harbour DLL for "other" App e.g. Xbase++ :idea:
in harbour Group Eric Lendvai point me to this Article
https://harbour.wiki/index.asp?page=Pub ... 2413934099
i have build Sample COM DLL and can now use it under Xbase++ (or any other) as ActiveX :)
! Note : Need CLASS Code Syntax
! Tip :
*.HBP File have HB_PATH which must SET to c:\hmg.3.4.4\HARBOUR
to "register" DLL, using BuildCOM.BAT , you must run "as Administrator"
gisjr134
Post by gisjr134 »
AUGE_OHR wrote: Mon May 30, 2022 1:02 pm hi Georgy,
Hi Everyone ,
With the utility QPM you may do it . There is a option 'Create Dll interface Library' , Where you will create one Dll originated from other DLL made it in Harbour\Mingw.
