TIMER in a CLASS
TIMER in a CLASS
how can i use a TIMER in a CLASS :?:
   oWin := "VLCAXWIN_" + STRZERO( i, 3 )
   oControl := "AXCTRL_" + STRZERO( i, 3 )
   cTimer   := "Timer_"+ STRZERO( i, 3 )
   DEFINE WINDOW &oWin ;
      DEFINE ACTIVEX &oControl
      END ACTIVEX
      DEFINE TIMER &cTimer of &oWin INTERVAL 10 ACTION IF(!EMPTY(oVLC), DoCheckTimer(ThisWindow.Name) , nil)
Control: Timer_016 Of VLCAXWIN_016 Not defined. Program Terminated
Re: TIMER in a CLASS
AUGE_OHR wrote: Tue May 24, 2022 2:40 pm hi,
May be
  DATA  cTimer
   ::cTimer   := "Timer_"+ STRZERO( i, 3 )
      END ACTIVEX
      DEFINE TIMER &( ::cTimer ) of &oWin INTERVAL 10 ACTION IF(!EMPTY(oVLC), DoCheckTimer(ThisWindow.Name) , nil)
hi Grigory,
my last Message was not clear
it "seems" that TIMER did not work when "Set" in Main when have a ActiveX
i need to use TIMER "in" CLASS where i can have Multi-Instance
   oVlc := TVlc() :New( GetProperty( oWin, oControl, "Object" ), oWin )
METHOD New( oControl, oWin ) CLASS TVlc
LOCAL cTimer    := "Timer_VLC"
  ::oWin := oWin
  ::lRun := .F.
  DEFINE TIMER &cTimer of &oWin INTERVAL 100 ACTION ::ShowRunThread()
METHOD Destroy() CLASS TVlc
   IF IsControlDefined( Timer_VLC, ::oWin )
      DoMethod( ::oWin, "Timer_VLC", "Release" )
METHOD ShowRunThread() CLASS TVlc
IF ::lRun = .T.
   nPlayState := ::State()
   CASE nPlayState = VLC_INPUT_STATE_PLAYING
      nDuration := INT( ::GetLength() / 1000 )
      IF !EMPTY( nDuration )
         IF nPosi >= nDuration - 1
            ::Stop()
            ::lRun = .F.
            IF SP_Loop() = .T.
              ::SetTime( 0 )
              ::Play()
            ELSEIF SP_Endless()  = .T.
              // SENDKEY( VK_NEXT )
              ::Play_Next()
