Microsoft INK Regcognizer
i try to re-write a Xbase++ Sample to HMG but i have "Problem" with this Syntax
   aBin := myInkCollector:Ink:Save( IPF_GIF, IPCM_Default )
i try to "split" line
   oInk := myInkCollector:Ink
   if hb_IsObject(oInk)
      aBin := oInk:Save( IPF_GIF, IPCM_Default )
but still fail ...
"draw" a Word, like "Hello" into upper Field and press "Recognize"
you will see in Editbox "Hello"
now i want to "save" Image where i have "draw" Word "Hello" ... but it crash
it does work under Xbase++ ( see \OLD )
HBINK.ZIP
(1.1 MiB) Downloaded 193 times
p.s. Xbase++ use a "Groupbox" -> WC_STATIC with Frame as "Parent" -> Hwnd
i use a LABEL ... not sure if it is "right" Control for it
Re: Microsoft INK Regcognizer
have found a Workaroud to "save" Image
   ACTION SaveInk( ThisWindow.Name,"Label_1","TEST.GIF",BT_FILEFORMAT_GIF )
PROCEDURE SaveInk( cForm, cControl, cFileName, nTypePicture )
LOCAL hBitmap
LOCAL nROW    := GetProperty(cForm, cControl, "ROW"   )
LOCAL nCOL    := GetProperty(cForm, cControl, "COL"   )
LOCAL nWIDTH  := GetProperty(cForm, cControl, "WIDTH" )
LOCAL nHEIGHT := GetProperty(cForm, cControl, "HEIGHT")
   hBitmap := BT_BitmapCaptureClientArea( cForm, nRow, nCol, nWidth, nHeight )
   BT_BitmapSaveFile( hBitmap, cFileName, nTypePicture )
   MsgInfo("Save " + cFileName)
now i can get Signature and "identify" it and get a Image to store ino Database.
HBINK2.ZIP
(167.14 KiB) Downloaded 143 times
p.s. have made Help File InkObj.chm to get a Overview of MSINKAUT
AUGE_OHR wrote: Fri Mar 25, 2022 12:44 am hi,
but still fail ...
HI.
Here you have a corrected prg:
* modyfied by edk
*+ Source Module => c:\hmg.3.4.4\0\INK\\HBINK.PRG
*+    Copyright(C) 1983-2021 by Auge & Ohr
*+    Functions: Procedure MAIN()
*+               Procedure DoInitInk()
*+               Procedure RecognizeInk()
*+               Procedure SaveInk()
*+    Reformatted by Click! 2.05.39 on Mar-25-2022 at  1:09 am
#include "HMG.CH"
#include "fileio.ch"
#include "inksdk.ch"
STATIC myRecognizers
STATIC myInkCollector
MEMVAR _HMG_SYSDATA
*+    Procedure MAIN()
PROCEDURE MAIN
   DEFINE WINDOW InkMain ;
         AT 0, 0 ;
         WIDTH 550 ;
         HEIGHT 350 ;
         TITLE "" ;
         ICON NIL ;
         ON INIT DoInitInk() ;
         ON RELEASE Nil ;
         ON INTERACTIVECLOSE Nil ;
         NOSIZE ;
         NOMAXIMIZE ;
         NOMINIMIZE ;
         ON PAINT Nil ;
         BACKCOLOR { 192, 192, 192 }
#define Use_Label
#ifdef Use_Label
      DEFINE LABEL Label_1
         ROW 10
         COL 15
         WIDTH 500
         HEIGHT 120
         VALUE ""
         FONTNAME "Arial"
         FONTSIZE 12
         TOOLTIP "write or draw something"
         VISIBLE .T.
         TRANSPARENT .F.
         ACTION Nil
         AUTOSIZE .F.
         BACKCOLOR Nil
         FONTCOLOR Nil
      END LABEL
#else
      DEFINE IMAGE Image_1
         ROW 10
         COL 15
         WIDTH 500
         HEIGHT 120
         PICTURE nil
         VISIBLE .T.
         //          STRETCH .T.
         ACTION nil
         TRANSPARENT .T.
         BACKGROUNDCOLOR WHITE
      END IMAGE
#endif
      DEFINE BUTTON Button_Ink
         ROW 134
         COL 15
         WIDTH 230
         HEIGHT 40
         ACTION RecognizeInk()
         CAPTION "&Recognize"
         FONTNAME "Arial"
         FONTSIZE 12
         TOOLTIP "Recognize what have input"
         ONGOTFOCUS Nil
         ONLOSTFOCUS Nil
         FLAT .F.
         TABSTOP .T.
         VISIBLE .T.
         TRANSPARENT .F.
         MULTILINE .F.
         PICTURE Nil
         PICTALIGNMENT TOP
      END BUTTON
      DEFINE BUTTON Button_Save
         ROW 134
         COL 285
         WIDTH 230
         HEIGHT 40
         ACTION SaveInk()
         CAPTION "&Save"
         FONTNAME "Arial"
         FONTSIZE 12
         TOOLTIP "Save Input to GIF"
         ONGOTFOCUS Nil
         ONLOSTFOCUS Nil
         FLAT .F.
         TABSTOP .T.
         VISIBLE .T.
         TRANSPARENT .F.
         MULTILINE .F.
         PICTURE Nil
         PICTALIGNMENT TOP
      END BUTTON
      DEFINE EDITBOX Edit_1
         ROW 180
         COL 15
         WIDTH 500
         HEIGHT 120
         VALUE ""
         FONTNAME "Arial"
         FONTSIZE 12
         TOOLTIP "Result Recognize"
         ONCHANGE Nil
         ONGOTFOCUS Nil
         ONLOSTFOCUS Nil
         TABSTOP .T.
         VISIBLE .T.
         READONLY .F.
         HSCROLLBAR .T.
         VSCROLLBAR .T.
         DISABLEDBACKCOLOR Nil
         DISABLEDFONTCOLOR Nil
         BACKCOLOR Nil
         FONTCOLOR Nil
      END EDITBOX
   CENTER WINDOW InkMain
   ACTIVATE WINDOW InkMain
*+    Called from ( hbink.prg )   1 - procedure main()
PROCEDURE DoInitInk()
LOCAL nHwnd
#ifdef Use_Label
   nHwnd := GetControlHandle( "Label_1", "InkMain" )
#else
   nHwnd := GetControlHandle( "Image_1", "InkMain" )
#endif
   // Create the recognizers collection
   myRecognizers := CreateObject( "msinkaut.InkRecognizers" )
   // Create a new ink collector that uses the Frame's window
   myInkCollector := CreateObject( "msinkaut.InkCollector" )
   myInkCollector:hWnd := nHwnd
   // Turn the ink collector on
   myInkCollector:Enabled = .T.
PROCEDURE RecognizeInk()
LOCAL nHwnd   := GetControlHandle( "Edit_1", "InkMain" )
LOCAL cString
   // Check to ensure that the user has at least one recognizer installed
   // Note that this is a preventive check - otherwise, an exception will
   // occur during recognition
   IF 0 == myRecognizers:Count
      MsgInfo( "There are no handwriting recognizers installed." + CRLF + ;
               "You need to have at least one in order to run this sample." )
      // Note that the Strokes' ToString() method is a
      // shortcut  for retrieving the best match using the
      // default recognizer.  The same result can also be
      // obtained using the RecognizerContext.
      cString := myInkCollector:Ink:Strokes:ToString()
      SetProperty( "InkMain", "Edit_1", "Value", cString )
      // If the mouse is pressed, do not perform the recognition -
      // this prevents deleting a stroke that is still being drawn
      * ? wrong ? * IF .NOT. myInkCollector:CollectingInk
      IF myInkCollector:CollectingInk
          // Delete the ink from the ink collector
          myInkCollector:Ink:DeleteStrokes( myInkCollector:Ink:Strokes )
          // Force the Frame to redraw (so the deleted ink will go away)
         InvalidateRect( nHwnd, 0 )
PROCEDURE SaveInk()
LOCAL oInk
   ALTD()
   IF hb_IsObject( oInk )
      IF oInk:Strokes:Count > 0
      	StrFile ( oInk:Save( IPF_GIF, IPCM_Default ), "testfile.gif" )
      	MsgInfo ( "No Strokes" )
      MsgInfo( "no Ink Object" )
*+ EOF: HBINK.PRG
  1. I think, you used myInkCollector:CollectingInk incorrectly. After recognizing the ink, you deleted the strokes :?:
  2. Before the Save method, get the number of strokes. If there are no strokes then you cannot use this method.
  3. Saving the result of the Save method does not require serialization, you get a pure string of bytes to save.
Edward,
missing inksdk.ch ?
serge_girard wrote: Tue Mar 29, 2022 8:47 am Edward,
missing inksdk.ch ?
My code complements the Jimmy's snippet (post viewtopic.php?p=68385#p68385). There you have all the files: https://www.hmgforum.com/download/file.php?id=11211
Hola jimmy :
Felicidades por tu código
He modificado tu código para poder
"Limpiar pantalla" no se si está correcto ?
1-Botón Borra solo Tinta
2-Botón Borra Tinta y Editor
Hay 4 diferentes maneras de Salvar el fichero
==> Gif,Jpg,Png,Bmp en Carpeta ==> Organize
he incorporado un sencillo fichero DBF
para que haga de Contador de los ficheros
Espero que sea de tu aprobación
Un cordial saludo
**************** Google ******************
Hi jimmy :
Congratulations for your code
I have modified your code to be able to
"Clean screen" I don't know if it's correct?
1-Button Erase Ink only
2-Button Erase Ink and Editor
There are 4 different ways to save the file
==> Gif,Jpg,Png,Bmp in Folder ==> Organize
I have incorporated a simple DBF file
to act as file counter
I hope it is of your approval
Cordial greeting
HBINK3.ZIP
(26.17 KiB) Downloaded 165 times
Hi Mustafa,
Great, that was I also wanted. Did you work on Edward's version?
hi serge
oui monsieur , je... je...
I'm doing tests
Hi Serge
With the permission of mr. Edward (edk)
here my contribution
* modyfied by edk
#include "HMG.CH"
STATIC numeroQ := 0
STATIC cFileName
STATIC DirNc , aStruct
STATIC miras := ".Gif"
MEMVAR _HMG_SYSDATA
*+    Procedure MAIN()
PROCEDURE MAIN
SET TOOLTIPSTYLE BALLOON
   DirNc  := HB_Curdrive() +":\"+Rtrim(Curdir() ) + "\"
   IF !HB_DirExists(".\Organize" )
           DirMake( ".\Organize" )
   DIRCHANGE( DirNc )
   IF ! FILE("CapNum.dbf")
        Contador_1()
         AT 0, 0          ;
         WIDTH  537       ;
         HEIGHT 430       ;
         TITLE ""         ;
         ICON NIL         ;
         ON RELEASE Nil   ;
         NOSIZE           ;
         NOMAXIMIZE       ;
         NOMINIMIZE       ;
         ON PAINT Nil     ;
         ON KEY ESCAPE ACTION  ThisWindow.Release
#define Use_Label
#ifdef Use_Label
         ROW 10
         COL 15
         WIDTH 500
         HEIGHT 120
         VALUE ""
         FONTNAME "Arial"
         FONTSIZE 12
         VISIBLE .T.
         TRANSPARENT .F.
         ACTION Nil
         AUTOSIZE .F.
         BACKCOLOR Nil
         FONTCOLOR Nil
      END LABEL
#else
         ROW 10
         COL 15
         WIDTH 500
         HEIGHT 120
         PICTURE nil
         VISIBLE .T.
         //          STRETCH .T.
         ACTION nil
         TRANSPARENT .T.
      END IMAGE
#endif
      DEFINE RADIOGROUP Radio_1
         ROW   136
         COL   150
         OPTIONS   { 'Gif','Jpg','Png','Bmp' }
         VALUE 1
         WIDTH 110
         FONTNAME "Arial"
         FONTSIZE 10
         TOOLTIP ''
         HORIZONTAL .T.
         SPACING 055
         ONCHANGE Busca_Format()
     END RADIOGROUP
         ROW 167
         COL 15
         WIDTH 232
         HEIGHT 40
         CAPTION "&Regcognize"
         FONTNAME "Arial"
         FONTSIZE 12
         TOOLTIP "Regcognize what have input"
         ONGOTFOCUS Nil
         ONLOSTFOCUS Nil
         FLAT .F.
         TABSTOP .T.
         VISIBLE .T.
         TRANSPARENT .F.
         MULTILINE .F.
         PICTURE Nil
         PICTALIGNMENT TOP
      END BUTTON
         ROW 167
         COL 283
         WIDTH 232
         HEIGHT 40
         ACTION SaveInk()
         CAPTION "&Save"
         FONTNAME "Arial"
         FONTSIZE 12
         ONGOTFOCUS Nil
         ONLOSTFOCUS Nil
         FLAT .F.
         TABSTOP .T.
         VISIBLE .T.
         TRANSPARENT .F.
         MULTILINE .F.
         PICTURE Nil
         PICTALIGNMENT TOP
      END BUTTON
         ROW   216
         COL   15
         WIDTH 500
         HEIGHT 120
         VALUE ""
         FONTNAME "Arial"
         FONTSIZE 12
         TOOLTIP "Result Regcognize"
         ONCHANGE Nil
         ONGOTFOCUS Nil
         ONLOSTFOCUS Nil
         TABSTOP .T.
         VISIBLE .T.
         READONLY .F.
         HSCROLLBAR .T.
         VSCROLLBAR .T.
         BACKCOLOR Nil
         FONTCOLOR Nil
      END EDITBOX
      DEFINE BUTTON Button_Clea1
         ROW   346
         COL   015
         WIDTH 111
         HEIGHT 40
         ACTION Cleaner1()
         CAPTION "&Cleaner-1"
         FONTNAME "Arial"
         FONTSIZE 12
         TOOLTIP "Clean Ink Only"
         ONGOTFOCUS Nil
         ONLOSTFOCUS Nil
         FLAT .F.
         TABSTOP .T.
         VISIBLE .T.
         TRANSPARENT .F.
         MULTILINE .F.
         PICTURE Nil
         PICTALIGNMENT TOP
      END BUTTON
     DEFINE BUTTON Button_Clea2
         ROW   346
         COL   136
         WIDTH 111
         HEIGHT 40
         ACTION Cleaner2()
         CAPTION "&Cleaner-2"
         FONTNAME "Arial"
         FONTSIZE 12
         TOOLTIP "Cleaner Ink and Editor"
         ONGOTFOCUS Nil
         ONLOSTFOCUS Nil
         FLAT .F.
         TABSTOP .T.
         VISIBLE .T.
         TRANSPARENT .F.
         MULTILINE .F.
         PICTURE Nil
         PICTALIGNMENT TOP
      END BUTTON
      DEFINE BUTTON Button_Exit
         ROW 346
         COL 283
         WIDTH 232
         HEIGHT 40
         CAPTION "&Exit"
         FONTNAME "Arial"
         FONTSIZE 12
         TOOLTIP "Exit"
         ONGOTFOCUS Nil
         ONLOSTFOCUS Nil
         FLAT .F.
         TABSTOP .T.
         VISIBLE .T.
         TRANSPARENT .F.
         MULTILINE .F.
         PICTURE Nil
         PICTALIGNMENT TOP
      END BUTTON
LOCAL nHwnd
#ifdef Use_Label
#else
#endif
LOCAL cString
PROCEDURE SaveInk()
LOCAL oInk
  Contador_2()
   ALTD()
              StrFile ( oInk:Save( IPF_GIF, IPCM_Default ), cFileName  )
  dbCloseAll()
  SELECT 1
  USE CapNum
  UNLOCK ALL
  IF CAPNUM->REC1  == 99999
     CapNum->( FLOCK() )
  IF CapNum->( RLOCK() )
     REPLACE CAPNUM->REC1 WITH 1
     REPLACE CAPNUM->REC2 WITH ALLTRIM( STRZERO( CAPNUM->REC1  ,5 ) )
     REPLACE CAPNUM->DATE WITH DATE()
     REPLACE CAPNUM->HORA WITH TIME()
     CapNum->( dbCOMMIT() )
  UNLOCK ALL
  CapNum->( FLOCK() )
     REPLACE CAPNUM->REC1 WITH CAPNUM->REC1  + 1
  UNLOCK ALL
*+ EOF: HBINK.PRG
PROCEDURE Cleaner1()
 LOCAL cString
 DoInitInk()
 InkMain.Label_1.Value := " "
 SetProperty( "InkMain", "Label_1", "Value", cString )
PROCEDURE Cleaner2()
 LOCAL cString
 DoInitInk()
 RecognizeInk()
PROCEDURE Contador_1()
   aStruct := { ;
  { "REC1"      , "N", 5, 0 }, ;
  { "REC2"      , "C", 5, 0 }, ;
  { "DATE"      , "D", 8, 0 }, ;
  { "HORA"      , "C", 8, 0 }  ;
  DbCreate( "CapNum", aStruct, .T. )
   dbCloseAll()
   SELECT 1
   USE CapNum
   UNLOCK ALL
   CapNum->( FLOCK() )
      ZAP
      dbAppend()
      REPLACE CAPNUM->REC2 WITH STRZERO( CAPNUM->REC1 ,5)
   UNLOCK ALL
   numeroQ   :=  ALLTRIM( CAPNUM->REC2 )
   cFileName := "Organize\" + numeroQ + miraS
PROCEDURE Contador_2()
   UNLOCK ALL
   SELECT 1
   USE CapNum
   dbGoTop()
   IF CAPNUM->REC1 == 0
      dbCloseAll()
      FileDelete("CapNum.dbf")
      Contador_1()
   cFileName := "Organize\"+ numeroQ + miraS
 FUNCTION Busca_Format()
DO CASE
CASE InkMain.Radio_1.Value == 1
     miraS := ALLTRIM('.Gif')
CASE InkMain.Radio_1.Value == 2
     miraS := ALLTRIM('.Jpg')
CASE InkMain.Radio_1.Value == 3
     miraS := ALLTRIM('.Png')
CASE InkMain.Radio_1.Value == 4
     miraS := ALLTRIM('.Bmp')
OTHERWISE
ENDCASE
RETURN(.F.)
Regards, Regards, Salam :lol: :D
hi Edward,
Thx for your Comment.
i have upload INK Sample while i had Problem to "save" Image which work under Xbase++
Sample is "just" a Part of much bigger Project which will include Codepage to recognize more than English Words
Note : under Xbase++ i have Problem when use Chinese Sign with DBCS
@Mustafa
Thx for upload
