VLC IPTV how to play *.m3u8
i can play "local" file in my HMG VLC App using
      ::oPlaylist:items:clear()
      ::oPlaylist:add( "File:///" + ::cFileName )
      ::oInput:position := 0
      IF HB_ISBLOCK( ::bOnSetFile )
         EVAL( ::bOnSetFile, Self, cFileName )
now i got a *.m3u8 File which i can open/play in VLC "direct"
i have to use URL like https://mcdn.daserste.de/daserste/de/master.m3u8 in VLC Player
but how to play in "my App" ? i try
      ::oPlaylist:add( "https://mcdn.daserste.de/daserste/de/master.m3u8" )
but that seems not to work.
attached ZIP include *.m3u for many IPTV Station
ZZ_PLAYLIST_ALL_TV.m3u does contain all
Countries-master.zip
(296.94 KiB) Downloaded 190 times
Re: VLC IPTV how to play *.m3u8
Maybe just the name of file master.m3u8 ...
It gives too many errors...
have figure out how to play IP-TV using VLC
Demo will create a "Config.INI" where you can change Size of App ( Default 800x600 )
after start IPTV.EXE it will show Main Window where you got a List of free TV / Radio Station
to use "your" Language use Combobox to set "Filter"
IPTV004.ZIP
(1.86 MiB) Downloaded 160 times
! Note : Config.INI does have
Country=
which will used for Combobox
to start free TV / Radio Station Dblclick in BROWSE or on "Logo" of Station ( unknown = "i" )
it will "minimize" Main to Task-Tray and open a new Windows in Full-HD (1920x1080)
you can resize Windows if TV ( Radio only small Titlebar)
if DblClick it will change into FullScreen / Normal
press ESC tp close Window -> Main appear again
btw. Dblclick on Task-Tray Icon will hide/show Main App
sometimes it need some Time until Connection is done so "wait" ...
but also a URL my be "not valid anymore" ... don´t know how to "check it" (yet)
last Version was 32 Bit so it need 32 Bit VLC which i have also used for my Xbase++ App.
but on 64 Bit OS most have 64 Bit Version of VLC installed which will NOT work wirh 32 Bit VLC Engine
so i create 64 Bit HMG App using 64 Bit VLC Engine
new :
Ctrl + F : LOCATE for Channel-No, Name or Country (TVGROUP)
! Note : it work CASE sensitive
! Tip : try
Star
and click on "Star Trek" :D
Taskline in VLC Player Windows ( now real Full-HD ) will automatic hide after some Time
when move over Taskline you can right-click to get Context Menu ( work with Table PC )
in Main Windows right-click Context Menu to "read" *.m3u8 File into (UNICODE) DBF
! Note : new DBF will have same Name as *.m3u8 File in same Folder
before start new Version please delete *.CDX which will be create new ( without UPPER() )
IPTV64_6.zip
(1.9 MiB) Downloaded 146 times
Hola Jimmy
Lo siento, mi VLC es portable...
Hi jimmy
Sorry, my VLC is portable...
hi Andy,
andyglezl wrote: Tue Mar 15, 2022 5:11 pm Sorry, my VLC is portable...
i "think" COM-Interface need Registry Stetting
            PROGID "VideoLAN.VLCPlugin.2"
which is not available in Portable Version (without Manifest File which include it )
based on this Thread
https://groups.google.com/g/harbour-users/c/sjeytL6zUPs
here new Design using DWM
it does NOT have a Inage as Background ... it IS "Transparent"
IPTV32_7.zip
32 Bit
(1.76 MiB) Downloaded 147 times
IPTV64_7.zip
64 Bit
(1.79 MiB) Downloaded 161 times
have found out that i have "read" *.m3u "incomplete" ... there are more than 3000 Station in *.m3u List
here "full" IPTVDBF.DBF and new Code to "show" how i got Information from *.m3u File
READM3U.ZIP
(186.64 KiB) Downloaded 154 times
! Note : Source does have Code, e.g. for Progressbar, which is not need to get Code work as Standalone
p.s. Delete *.CDX before start with new DBF ( will be create new *.CDX )
