tip_URLEncode + instead of %20
Posted: Mon Feb 21, 2022 5:49 pm
by trmpluym
Dear friends,
To use an WEB API call I am required to encode a string with URLEncode
https://en.wikipedia.org/wiki/Percent-encoding
In Harbour this can be done using the tip_URLEncode function (HBTIP Library).
So I tried the simple line below:
MsgDebug( tip_URLEncode("Microsoft Office") )
I was expecting the result below:
Microsoft%20Office
But instead I got:
Microsoft+Office
I found out both "+" and "%20" are used to replace a SPACE character.
In the link below the statement is "%20" is more modern:
https://stackoverflow.com/questions/163 ... cter-or-20
Is there a modified version or alternative function to do the URLEncoding ?
Theo
Re: tip_URLEncode + instead of %20
Posted: Wed Feb 23, 2022 10:13 pm
by Claudio Ricardo
Hi, if you need only replace space with "%20", can try:
MsgDebug ( StrTran ( "Microsoft Office", " ", "%20" ) )
Or...
MsgDebug ( StrTran ( Tip_UrlEncode ( "Microsoft Office" ), "+", "%20" ) )
Posted: Mon Feb 28, 2022 10:49 am
by trmpluym
Hi Claudio,
Thanks for taking the time to answer my question !
In the end my problem was no problem at all because the API can also use the alternative + encoding in stead of the %20 encoding :D
Sorry for bothering !
Theo
