How to trigger button click events programmatically?
Hello,
Re: How to trigger button click events programmatically?
Just call the function whenever required!
That's one way!
Can I send a message trigger using SENDMESSAGE()? , if possible, how to write code?
No me queda clara la pregunta...
The question is not clear to me...
FUNCTION Main()
DEFINE WINDOW FormMain . . . . .
@ nRen , nCol BUTTON BTN1 OF FormMain CAPTION "ALGO" WIDTH 25 HEIGHT . . . . . ONCLICK MsgBox("Title")
ON KEY CTRL+ALT+BACK OF FormMain ACTION MsgBox("Title")
ON KEY F2 OF FormMain ACTION MsgBox("Title")
DEFINE CONTEXT MENU OF FormMain
MENUITEM "ALGO" ACTION MsgBox("Title")
END MENU
MsgBox("Title")
ACTIVATE WINDOW FormMain
Hi, try:
viewtopic.php?p=66597#p66597
Eval ( _GetControlAction ( <cButtonName> , <cParentWindowName> ) )Re: How to trigger button click events programmatically?
Hello,
or why not use :
domethod( "cWinname", "cButtonId", "ONCLICK")
Hans
or why not use :
Hans
Hi Edk,
i am sorry to say but this method does exist, see button example below.
Hans
Hans
Function Main()
set century on
set date ital
DEFINE WINDOW Form_1 ;
WIDTH 300 ;
HEIGHT 300 ;
MAIN;
TITLE 'Button Test'
DEFINE MAIN MENU
POPUP 'Test'
ITEM 'Disable button' ACTION Form_1.Button_1.Enabled := .f.
ITEM 'Enable button' ACTION Form_1.Button_1.Enabled := .t.
END POPUP
END MENU
@ 30,30 BUTTON Button_1 PICTURE "button.bmp" WIDTH 50 HEIGHT 50 ACTION getprinter()
@ 30,90 BUTTON Button_2 CAPTION "Sim Onclick button 1" WIDTH 150 HEIGHT 50 ACTION Sim_Onclickbutton1()
@ 150,70 textbox t1 value date() date
CENTER WINDOW Form_1
ACTIVATE WINDOW Form_1
function Sim_Onclickbutton1()
domethod("Form_1","Button_1","onclick")
return nilRe: How to trigger button click events programmatically?
So this method is not documed https://www.hmgforum.com/hmgdoc/data/button.htm
Thank you very much to Rathinagiri, EDK and Hansmarc for answering,
After trying to trigger a button in a program, there are several ways:
1, doMethod (cWinname cButtonid, "onClick")
2, Eval(_GetControlAction(cButtonid, cWinname))
3, SendMessage(GetControlHandle(cButtonid, cWinname),BM_CLICK,0,0)
