WLAERT.PRG - REPLACEMENT FOR ALERT()
Posted: Sat Jan 29, 2022 2:40 am
by CCH4CLIPPER
Hi All
Tried to add walert() as a replacement for Alert()
But cannot compile with error msgs
What am I missing ?
hbmk2: Error: Referenced, missing, but unknown function(s):
_DEFINEMODALWINDOW(), _DEFINEHOTKEY(), DOMETHOD(), _DEFINELABEL(),
GETPROPERTY(), _DEFINEBUTTON(), SETPROPERTY(), GETBORDERWIDTH(),
_ENDWINDOW(), _ACTIVATEWINDOW()
* WALERT()
* Direct replacement for Clipper ALERT() function
* Copyright 2006 Ricardo Sassy <rsassy@gmail.com>
* www - http://www.harley.com.ar
* This program is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
* FUNCTION walert( cMessage, aItems, cTitle ) ==> nValue returned
* cMessage: Message to be displayed inside ALERT frame. Can contain ";"
* character(s) to line feed efect.
* aItems : (optional) An array of choices. If empty, a "OK" button will
* be displayed and return "0" value.
* cTitle : (optional) A title for ALERT window. If empty, default to "choice" message.
* Function return numeric value from 1 to 4 according to button pressed
* or 0 (zero) value in case of interactive window closing.
* In case of translate from original Clipper code to Minigui code
* only replace "ALERT" word for "WALERT" word.
* Sample of Clipper code : ALERT('Please;Choice output...',{'PRINTER','SCREEN'})
* Sample of Minigui code : WALERT('Please;Choice output...',{'PRINTER','SCREEN'})
#include "minigui.ch"
#define MsgInfo( c ) MsgInfo( c, , , .f. )
Procedure Main
DEFINE WINDOW Win_1 ;
WIDTH 600 ;
HEIGHT 400 ;
TITLE 'WALERT Function Test' ;
DEFINE BUTTON Button_1
ROW 10
COL 10
CAPTION 'Test 1'
ACTION MsgInfo( "WALERT Return = " + ltrim(str(WALERT('This is;an information screen;ONLY...',,'Information'))) )
END BUTTON
DEFINE BUTTON Button_2
ROW 40
COL 10
CAPTION 'Test 2'
ACTION MsgInfo( "WALERT Return = " + ltrim(str(WALERT('Please;Choice output...',{'PRINTER','SCREEN'}))) )
END BUTTON
DEFINE BUTTON Button_3
ROW 70
COL 10
CAPTION 'Test 3'
ACTION MsgInfo( "WALERT Return = " + ltrim(str(WALERT('Please;Choice output...',{'PRINTER','SCREEN','MAIL'}))) )
END BUTTON
DEFINE BUTTON Button_4
ROW 100
COL 10
CAPTION 'Test 4'
ACTION MsgInfo( "WALERT Return = " + ltrim(str(WALERT('Please;Choice output...',{'PRINTER','SCREEN','MAIL','FAX'}))) )
END BUTTON
DEFINE BUTTON Button_5
ROW 130
COL 10
CAPTION '&Close'
ACTION ThisWindow.Release
END BUTTON
CENTER WINDOW Win_1
ACTIVATE WINDOW Win_1
LOCAL I , J:=0 , nStart:=1 , nValue:=0 , cTextLabel
LOCAL nItemCount , nHeight , cBtnName
DEFAULT aItems TO {}
DEFAULT cMessage TO ' '
IF SET( _SET_LANGUAGE )=='ES'
DEFAULT cTitle TO 'Seleccione...'
DEFAULT cTitle TO 'Please, select'
cMessage := cMessage + ';'
DEFINE WINDOW walert ;
WIDTH 400 ;
HEIGHT 215 ;
TITLE cTitle ;
MODAL ;
NOSIZE
ON KEY ESCAPE ACTION walert.Release
//******************** DISPLAY MESSAGE *******************************
FOR I:=1 TO LEN(cMessage)
IF SUBSTR(cMessage,I,1)=';'
cTextLabel := 'text'+STR(++J,1)
@ J*20-10,016 LABEL &cTextLabel WIDTH 368 HEIGHT 20 VALUE SUBSTR(cMessage,nStart,I-nStart) ;
CENTERALIGN
nStart := I+1
NEXT I
//******************** DRAW BUTTONS ***********************************
nItemCount := LEN(aItems) // quantity of buttons
if nItemCount > 1
nStart := 200 - (nItemCount * 80 + (nItemCount - 1) * 20) / 2
80 - width of Button
20 - space between buttons
200 is half of width of walert window
nHeight := walert.Height
IF nItemCount <= 1
@ nHeight-70,160 BUTTON Button_1 ;
CAPTION '&OK' ;
ACTION {|| nValue := 0, walert.Release } ;
WIDTH 80 HEIGHT 28 DEFAULT
for i:=1 to nItemCount
cBtnName := "Button_"+str(i,1)
@ nHeight-70, nStart+100*(i-1) BUTTON &cBtnName ;
CAPTION '&'+aItems ;
ACTION {|| nValue := val(right(this.name,1)), walert.Release } ;
WIDTH 80 HEIGHT 28
next i
if nItemCount > 3
walert.Width := (walert.Width) + iif(_HMG_IsXP,2,1)*GetBorderWidth()
walert.Button_1.Setfocus
CENTER WINDOW walert
ACTIVATE WINDOW walert
RETURN(nValue)
Re: WLAERT.PRG - REPLACEMENT FOR ALERT()
Posted: Mon Jan 31, 2022 4:22 pm
by quartz565
I see that you work with minigui. You can use the new and very useful function, HMG_ALERT() with many possibilities.
Posted: Tue Feb 01, 2022 3:01 am
by CCH4CLIPPER
Hi
is hmg_alert() available in HMG.3.5 ?
Posted: Tue Feb 01, 2022 3:30 am
by CCH4CLIPPER
Hi All
Grigory explained that the default compilation for minigui is via bcc while Harbour 3.2 is by default using mingW. Thus the minigui lib is simply not available.
CCH4CLIPPER
Posted: Tue Feb 01, 2022 7:14 am
by AUGE_OHR
Afaik,
you must change "MINIGUI.CH" to "HMG.CH" to get it run
only Constant "_HMG_IsXP" is unknown ... but how is still using Windows XP
also
must be change to
WIDTH 80 HEIGHT 28
Posted: Tue Feb 01, 2022 12:23 pm
by quartz565
CCH4CLIPPER wrote: Tue Feb 01, 2022 3:01 am Hi
only with minigui
Posted: Tue Feb 01, 2022 1:17 pm
by CCH4CLIPPER
Its ok as I have modified Pritpal MyAlert() to.map to alert()
Thanks for responding
CCH4CLIPPER
