New Report Advanced
jouhmg
New Report Advanced
Post by jouhmg »
English by Google
Hi:
Joined a new application Advanced Report.
Compiler said to me:
"Undefined reference to HB_FUN_PDFINIT"
"Undefined reference to HB_FUN_PDFOPEN"
"Undefined reference to HB_FUN...
File (h_rptgen.c ):h_rptgen.c
Obviously I'm missing something
What is it? (PDF Functions)
TIA
jouhmg
Re: New Report Advanced
Which version of HMG are you using? Can you post the sample.prg?
jouhmg
Post by jouhmg »
English by Google
Hi:
Using HMG 2.9.3
Examples of Advanced Report function well.
Now, when incorporated into an application I get the error as if the missing file h_rptgen.c
The test is:
#include "minigui.ch"
Procedure Report
Use Test
LOAD REPORT Test
EXECUTE REPORT Test PREVIEW SELECTPRINTER
Use
jouhmg
Hello jouhmg,
I just tested Demo2.prg within C:\HMG\samples\REPORT.ADVANCED folder.
It runs Ok. :)
If possible, please rename your HMG folder to another folder (eg, HMG_Old) and Re install HMG. Then try to compile. :)
jouhmg
Post by jouhmg »
English by Google
Hello sudip:
I did as recommended but still the error.
It may be that the package of HMG h_rptgen.c file is missing?
In the folder C:\HMG\Source file is h_rptgen.prg but not the file h_rptgen.c
This is correct?
jouhmg
jouhmg wrote:English by Google
Hi:
Using HMG 2.9.3
Try to add the library hbvpdf to your link script by command:
-lhbvpdf
I hope that helps. :idea:
jouhmg
Post by jouhmg »
English by Google
Hello Grigory:
That was the solution. :)
QAC use version 4.11.16 and possibly this is not contemplating
the introduction of this library, which made me understand a
little more how this tool.
I confirmed with the author of QAC if so.
Thank you very much.
jouhmg
