HMG - Latest Status
CCH4CLIPPER
HMG - Latest Status
Post by CCH4CLIPPER »
Hi All
Its been 11 years since I last did a project in HMG via V3.0.35 :-(
Have just been commisioned to convert a legacy 5.2e project to Harbour. Have already done :
1. Successfully converted to Harour 3.2 using hbmk2 via mapping undefined functions from ancient libraries via mapping to hb functions
2. Have successfully mapped alert() to wapi_messagebox
3. Implemented basic GT functions for icon/windows title/gui windows
Next is to windows a window-like menu system etc
Just wondering :
1. What is the latest HMG version ?
2. Will this latest version break codes in Harbour 3.2
3. Will it break codes written for 3.0.35
CCH
cch4clipper.blogspot.com
Claudio Ricardo
DBs Used: DBF, MySQL, MariaDB
Re: HMG - Latest Status
Post by Claudio Ricardo »
Hello... The latest is 3.5 and you can download it here above where it says: Download HMG
If you want zero problems, recompile it with the same version and libraries with which it was created.
CCH4CLIPPER
Hi Claudio
1. Installed HMG.3.5 successfully
2. cd basics\main_demo folder & easily build demo.hbp
Then tried hbmk2 demo.hbp & got the following error messages
C:\HMG.3.5\SAMPLES\Basics\MAIN_DEMO>hbmk2 demo.hbp
Harbour 3.2.0dev (r1309161336)
Copyright (c) 1999-2013, http://harbour-project.org/
Compiling 'demo.prg'...
demo.prg(8) Error F0029 Can't open #include file 'hmg.ch'
hbmk2[demo]: Error: Running Harbour compiler (embedded). 1
(c:\harbour\hb32\bin\harbour.exe) -n2 demo.prg -oC:\Users\User\AppData\Local\Tem
p\hbmk_sc04p1.dir\ -ic:\harbour\hb32\include
What am I doing wrong ?
CCH4CLIPPER
Net copied contents of c:\hmg.3.5\include & recompile
as hbmk2 demo.hbp and got
C:/Users/User/AppData/Local/Temp/hbmk_jwgbnx.dir/demo.o:demo.c:(.data+0x7a8): u
defined reference to `HB_FUN_MEMORYSTATUS'
hbmk2[demo]: Error: Running linker. 1
c:\harbour\hb32\comp\mingw\bin\gcc.exe C:/Users/User/AppData/Local/Temp/hbmk_jw
bnx.dir/demo.o C:/Users/User/AppData/Local/Temp/hbmk_jwgbnx.dir/hbmk_4k9rmy.o
-mconsole -Wl,--start-group -lhbextern -lhbdebug -lhbvm -lhbrtl -lhblang -lhbc
age -lgtcgi -lgtpca -lgtstd -lgtwin -lgtwvt -lgtgui -lhbrdd -lhbuddall -lhbusrr
d -lrddntx -lrddcdx -lrddnsx -lrddfpt -lhbrdd -lhbhsx -lhbsix -lhbmacro -lhbcpl
-lhbpp -lhbcommon -lhbmainstd -lkernel32 -luser32 -lgdi32 -ladvapi32 -lws2_32
lwinspool -lcomctl32 -lcomdlg32 -lshell32 -luuid -lole32 -loleaut32 -lmpr -lwin
m -lmapi32 -limm32 -lmsimg32 -lwininet -lhbpcre -lhbzlib -Wl,--end-group -ode
o.exe -Lc:/harbour/hb32/lib/win/mingw
hbmk2: Error: Referenced, missing, but unknown function(s): _DUMMY(),
_DEFINEWINDOW(), _STARTSTATUSBAR(), _DEFINESTATUSBARITEM(),
_ENDSTATUSBAR(), _DEFINEHOTKEY(), MSGINFO(), _DEFINEMAINMENU(),
_DEFINEMENUPOPUP(), _DEFINEMENUITEM(), _DEFINESEPARATOR(),
_ENDMENUPOPUP(), DOMETHOD(), GETWINDOWSFOLDER(), GETSYSTEMFOLDER(),
GETMYDOCUMENTSFOLDER(), GETDESKTOPFOLDER(), GETPROGRAMFILESFOLDER(),
GETTEMPFOLDER(), GETFOLDER(), GETFILE(), PUTFILE(), PLAYBEEP(),
PLAYASTERISK(), PLAYEXCLAMATION(), PLAYHAND(), PLAYQUESTION(), PLAYOK(),
SHELLABOUT(), GETPROPERTY(), SETPROPERTY(), _ENDMENU(),
_DEFINECONTEXTMENU(), _DEFINELABEL(), _DEFINECHECKBUTTON(),
_DEFINEIMAGECHECKBUTTON(), _DEFINEBUTTON(), _DEFINEIMAGEBUTTON(),
_DEFINEMIXEDBUTTON(), _BEGINTAB(), _BEGINTABPAGE(), _DEFINEGRID(),
_ENDTABPAGE(), _BEGINFRAME(), _DEFINECHECKBOX(), _DEFINESLIDER(),
_DEFINERADIOGROUP(), _DEFINEEDITBOX(), _DEFINEPROGRESSBAR(), _ENDTAB(),
_DEFINEDATEPICK(), _DEFINECOMBO(), _DEFINELISTBOX(), _DEFINETEXTBOX(),
_DEFINEMASKEDTEXTBOX(), _DEFINECHARMASKTEXTBOX(), _DEFINESPINNER(),
_DEFINETIMER(), _DEFINEIMAGE(), _ENDWINDOW(), _ACTIVATEWINDOW(),
_EXECUTE(), GETACTIVEWINDOW(), INPUTWINDOW(), _DEFINEMODALWINDOW(),
GETCOLOR(), GETFONT(), _ISWINDOWACTIVE(), _ISWINDOWDEFINED(), MSGBOX(),
MSGSTOP(), MSGEXCLAMATION(), MSGYESNO(), MSGOKCANCEL(),
MSGRETRYCANCEL(), MEMORYSTATUS()
CCH4CLIPPER wrote: Mon Jan 24, 2022 8:34 am Then tried hbmk2 demo.hbp & got the following error messages
have you SET your PATH to all working Folder ... :?:
there a Build.BAT under C:\HMG which will SET Environment before call HBMK2
do not use HBMK2 "direct" when have not SET Environment e.g. for PATH
try this
C:\HMG.3.5\SAMPLES\Basics\MAIN_DEMO>..\..\build.bat demo.hbp
i do assign *.HBP to (Unicode) IDE so when dblclick on demo.HBP it will load IDE and i can press F5
CCH4CLIPPER
Hi Jimmy
Thanks for the speedy response.
Have already resolved issue via SET HMGPATH=C:\HMG.3.5
Claudio Ricardo
Hello, As Jimmy mentions, it is convenient to use the default path by HMG in the installation.
Also remember to never create folder or file names with spaces or it won't compile.
