Error abrir programa
Pepe Ruano
Post by Pepe Ruano »
Por favor alguien sabe porqué me aparece este error alguna vez ?
Gracias.
Please, does anyone know why I ever get this error?
Thanks.
Saludos - Regards
Pepe Ruano
hmg.ruano.org
Re: Error abrir programa
Try to run your application as an administrator and see if it will be ok. If so, check the permissions for the folder where you create the dbf file.
Pepe Ruano
edk wrote: Fri Dec 03, 2021 6:49 pm Try to run your application as an administrator and see if it will be ok. If so, check the permissions for the folder where you create the dbf file.
Thanks run O.K.
Gracias funciona bien, son los permisos.
Saludos - Regards
Pepe Ruano
hmg.ruano.org
