HMG_MYSYNC (New Version)
brunellopulix
Post by brunellopulix »
HI
I completely rewrote the procedure adding new options and correcting any inaccuracies I found.
I tested the procedure daily for a few months until I reached an optimal level of efficiency.
If you are using a previous version, I recommend that you use this version.
Brunello
HMG_MYSYNC.zip
(324.52 KiB) Downloaded 200 times
Re: HMG_MYSYNC (New Version)
Hi Brunello,
Thanks for this new version :!:
I saw that it's based upon the MiniGUI Ex now 8-)
brunellopulix
Hello
I'm sorry minor adjustments:
Procedure Main
FV3_Label('Leto Origin',70)
change to:
FV3_Label('Origin',70)
Procedure Start
before:
If aPaths[i,6] == 2
Zippy(cOrigin,cTarget)
change to:
FV3_SetProperty('ORIGIN','Value',cOrigin)
If aPaths[i,6] == 2
Brunello
fouednoomen
Post by fouednoomen »
Many thanks for your contribution , could you please sharing executable file .
brunellopulix
Brunello
HMG_MYSYNC.zip
(1.39 MiB) Downloaded 216 times
fouednoomen
Hi Brunello ,
Many thanks for you sharing files
Could you please explain to me step by step what I must change
in GFC.INI and. MYIP.TXT, can not understand you readme file
I work with Letodbf on a public ip adresse
Best regards
Foued Noomen
brunellopulix
CFG.INI:
-you need to update your IP (not important)
MYIP.TXT:
-you must enter the LETO server data in each line at the end enter the server port and then the end note with / *
example:
//192.168.1.100:2812/ /* My PC
or:
//192.168.1.101:2812/ /* PC1-HOME
//192.168.1.102:2813/ /* PC2-HOME
//192.168.1.103:2814/ /* PC3-HOME
IPs can be public
remember:
your leto server needs them for Minigui Ext
