"shell.explorer.2" and "Drop" from Outlook
"shell.explorer.2" -> IE-Engine can handle almost all Format which you "Drop" into it.
for HMG you need to "enable" it with
   DragAcceptFiles( Form.Control.HANDLE )
also a Event is need when something was "Drop"
   CREATE EVENT PROCNAME Drop_Detect(cForm, cControl) HWND Form.Control.HANDLE
now we can "wait" for
FUNCTION Drop_Detect(cDropForm, cDropCont)
LOCAL nMsg    := EventMSG()
LOCAL nWParam := EventWPARAM()
   DO CASE
      CASE nMsg == WM_DROPFILES
and "Query" what was "Drop"
         aFiles := DragQueryFileS( nWParam )
at that Point HMG Version work different to Xbase++
my HMG Version fail when try to Drop Email from Outlook :(
it does not show "+" at Cursor like under Xbase++ which allow "Drop" so something is missing ...
can someone tell me what i´m doing wrong under HMG :idea:
Re: "shell.explorer.2" and "Drop" from Outlook
i have ask in FiveWin Forum and Otto show me a Sample using RICHTEXT and "drop" Qutlook Email to it
so i look into FiveWin Source and found in \fwh\source\classes\triched5.prg -> \fwh\source\classes\window.prg
   METHOD SetOleInit()      INLINE RESetOleInit5()
   METHOD SetOleUnInit()    INLINE RESetOleUnInit5( ::hWnd )
   METHOD SetOleCallback()  INLINE RESetOleCallback5( ::hWnd )
   METHOD GetOleInterface() INLINE REGetOleInterface5( ::hWnd )
i guess it is like under Xbase++ (using Ot4Xb Syntax)
   @ole32:OleInitialize(0)
   @ole32:OleUninitialize()
Question : does HMG or MiniGUI Version use OLE :?:
have found out that i have to use "other" HMG Control to "drop" Email from Outlook to HMG :)
but i only got 1st Step so i need some time to figure out how to "add Code" to Access Outlook those Way
p.s. it should also work Outlook Calendar !
Hi Jimmy,
Keep us informed about this 'drag and drop' issue !
AUGE_OHR wrote: Fri Nov 19, 2021 11:20 am hi,
Quizá...
https://www.hmgforum.com/viewtopic.php?p=67567#p67567
En el navegador EDGE si funciona... (lo descarga)
Teniendo el archivo: "Audífonos ASUS_ todo para tus juegos _ Viaja a las Vegas CES _ Ver más ofertas CVA (1).msg"
Maybe ...
In the EDGE browser if it works ... (download it)
Having the file: "ASUS headphones_ everything for your games _ Travel to Vegas CES _ See more offers CVA (1) .msg "
cMsg := "Audífonos ASUS_ todo para tus juegos _ Viaja a las Vegas CES _ Ver más ofertas CVA (1).msg"
ShellExecute(0, "open", "rundll32.exe", cMsg, , 1)
C
hi Serge,
serge_girard wrote: Fri Nov 19, 2021 4:07 pm Keep us informed about this 'drag and drop' issue !
i got Sample working ... but it only work with German Version yet.
is it while i ask for
FUNCTION CheckHeaderLine(cTest)
LOCAL lRet := .F.
LOCAL nCountry := HB_bitAND( GETKEYBOARDLAYOUT(), 0xFFFF )
   DO CASE
      CASE nCountry = 1031   // Germany
         IF "Von"        $ cTest .AND. ;
            "Betreff"    $ cTest .AND. ;
            "Erhalten"   $ cTest .AND. ;
            "Kategorien" $ cTest
            lRet := .T.
   ENDCASE
RETURN lRet
so i need sone help from User of this Forum
use any RICHEDITBOX Control and "drop" Email from Outlook into it ;)
you need NO other Code or "Trick" to "drop" Email from Outlook into RICHEDITBOX :!:
you will become some Text which i need for "Keywords"
as i say this is the "Start-Point" to get hole Email and Attachment(s)
please copy "that" Line and post it here in Forum
also write what this Line give you fir nCountry
thx for help
hi
i have made a Demo EXE Version which will work (or not) without "Check"
"Check" does "only" work with German Message, other Language i can not test
OLRICH.zip
(1.46 MiB) Downloaded 65 times
please use this Demo "only" for Outlook Email :!:
"other" may work .. but it can also crash.
App will display at upper/left and "wait" for "drop"
as it is a "normal" RICHEDITBOX so you can use it in your App without any change
if you like it please post Snapshot of MessageBox for you Language
En español, parece OK
In Spanish, it seems OK
hi
as i say "this" Version is "un-lock" ... but you can "drop" more than Outlook Email which may crash ...
so please try "normal" RICHEDITBOX like \SAMPLES\Applications\MiniWriter\ and "drop" Email from Outlook to it
in German Version i got this in 1st Line
"Von Betreff Erhalten Größe Kategorien"
but as "Größe" have "special" Sign i use only 4 "Keywords" to identify Outlook Email
this is what i need from User of this Forum to made it "safe" before release Source
