Dynamic Display in a Context Menu
Posted: Sun Oct 31, 2021 5:55 pm
by Red2
I want to DYNAMICALLY display the GRID (current row's) CELL value in my CONTEXTMENU.
So far I have NOT been able to do this using a MACRO.
MY QUESTION:
Is it possible to dynamically display a CELL's value in a CONTEXTMENU?
Google Spanish:
Quiero mostrar DINÁMICAMENTE el valor de CELDA de GRID (fila actual) en mi CONTEXTMENU.
Hasta ahora NO he podido hacer esto usando una MACRO.
MI PREGUNTA:
¿Es posible mostrar dinámicamente el valor de una CELDA en un CONTEXTMENU?
Below I attempt to display a CELL's value of the current GRID row.
This gives: Error BASE/1449 Syntax error: &
private DynamicGridRowValue := Get_Dynamic_State()
DEFINE CONTROL CONTEXTMENU StatesGrid OF DisplayForm
MenuItem "Print for " + &( DynamicGridRowValue ) ACTION Do_Something( .T. )
MenuItem "Do NOT Print for " + &( DynamicGridRowValue ) ACTION Do_Something( .F. )
END MENU
function Get_Dynamic_State() // Dynamic State lookup in the Grid:
local hdl := GetControlHandle( "StatesGrid", "DataBrowse" )
local lnRow := ListView_GetFirstItem( hdl )
return GetProperty( "DataBrowse", "StatesGrid", "Cell", lnRow, 2 ) // Column #2 value
Re: Dynamic Display in a Context Menu
Posted: Fri Jun 10, 2022 5:15 pm
by Red2
I now have a solution that displays a CONTEXT MENU
dynamically according to
each GRID' Control's row.
(Unfortunately there is one exception).
What I did:
1) In the GRID's
OnChange Event I call a function where I
DEFINE CONTROL CONTEXT MENU and add the
MenuItems.
These are then generated specifically for that particular Row.
(Whenever
OnChange is triggered this works great!)
2) I adapted code in the
test.rar attachment that was posted by salamandra:
https://www.hmgforum.com/viewtopic.php? ... rightclick)
Specifically,
CREATE EVENT PROCNAME On_M_RClick()
and
FUNCTION On_M_RClick().
In my
FUNCTION On_M_RClick() I call the GRID's
OnChange Event.
When a Grid Row
already has
Focus then a
Right Click gives the
correct
CONTROL CONTEXT MENU for that particular row.
The One (Problem) Exception:
The very first
Right Click on a
NEW row does
not fire the
OnChange event
so the
CONTROL CONTEXT MENU that appears is from the
PREVIOUS Grid row!
(Interestingly a second
Right Click will SetFocus to this new Grid row and
OnChange fires.)
I have tried many things in my
On_M_RClick() code including
DoMethod( "DataBrowse", "BrowseStates", "SetFocus" )
and
Do Events
but have not been able here to simply set the Focus to this
new Grid Row.
Question:
How can Row Focus be
programmatically triggered within my function
On_M_RClick()?
I would greatly appreciate the kind help of someone more experienced with this difficult exception?
Thank you!
Red2
Posted: Sun Jun 12, 2022 8:40 am
Hi Red,
Maybe this can help you:
DEFINE WINDOW Form_ROUTE;
@ 70,30 GRID Grid_ROUTE ;
WIDTH 435 ;
HEIGHT 480 ;
HEADERS {'Dichter', 'Titel', 'Aktief' , 'Tekst file'};
WIDTHS { 200, 200 , 25 , 300 } ;
JUSTIFY {GRID_JTFY_LEFT, GRID_JTFY_LEFT, GRID_JTFY_LEFT, GRID_JTFY_LEFT};
FONT "Arial" SIZE 09 ;
VALUE {1,1} ;
ITEMS aRows ;
CELLNAVIGATION ;
BACKCOLOR {253, 254, 184 } ;
DYNAMICBACKCOLOR { bColor1 , bColor1 , bColor2 , bColor1 }
Define_Control_Context_Menu("Form_ROUTE","Grid_ROUTE", 1, 1, '', '') // Needs to start definition for this control
Define_Column_ToolTip("Form_ROUTE","Grid_ROUTE")
SET CONTROL Grid_ROUTE OF Form_ROUTE ONMOUSEEVENT Check_Grid_Events()
SetProperty('Form_ROUTE','Grid_ROUTE', 'Value', 1 )
SetProperty('Form_ROUTE','Grid_ROUTE', 'SetFocus', TRUE )
SetProperty('Form_ROUTE','BT_S', 'Enabled', PROT )
CENTER WINDOW Form_ROUTE
ACTIVATE WINDOW Form_ROUTE
return
STATIC FUNCTION Check_Grid_Events()
LOCAL aCell, nMsg := EventMsg()
STATIC cCtrlSelected := ""
IF nMsg == WM_RBUTTONDOWN
aCell := GetCellClicked("Form_ROUTE", "Grid_ROUTE")
IF EMPTY(aCell) .OR. aCell [1] == 0
RETURN Nil
SetProperty("Form_ROUTE", "Grid_ROUTE", "Value", aCell)
cKEY1 := aRows [ aCell [1], 1 ] + '#' + aRows [ aCell [1], 2 ] + '#' + aRows [ aCell [1], 4 ] // HIER
Define_Control_Context_Menu("Form_ROUTE", "Grid_ROUTE", aCell[2], aCell[1], cKEY1, ALLTRIM(aRows [ aCell [1], 2 ]) )
RETURN Nil
STATIC FUNCTION GetCellClicked(cForm,cControl)
LOCAL aRet, nIndex := GetControlIndex(cControl,cForm)
LOCAL aCellData := _GetGridCellData(nIndex)
aRet := {aCellData[1],aCellData[2]}
RETURN aRet
STATIC FUNCTION Define_Control_Context_Menu(cParentForm, cControl, nColumn, nRow, cKEY1, cKEY2)
IF IsControlContextMenuDefined( cControl, cParentForm )
ReleaseControlContextMenu( cControl, cParentForm )
IF !EMPTY(cKEY1)
DEFINE CONTROL CONTEXTMENU &cControl OF &cParentForm
ITEM " Aktiveer " + cKEY2 ACTION Aktiveer(cKEY1, 'J')
ITEM " DesAktiveer " + cKEY2 ACTION Aktiveer(cKEY1, 'N')
ITEM " Vernieuw " + cKEY2 ACTION Vernieuw(cKEY1)
ITEM " Open tekst " + cKEY2 ACTION Open_RTF(cKEY1)
ITEM " Verwijder " + cKEY2 ACTION Aktiveer(cKEY1, 'X')
END MENU
RETURN Nil
STATIC FUNCTION Define_Column_ToolTip(cParentForm,cControl)
LOCAL nColumn := GetProperty(cParentForm,cControl, "CellColFocused")
LOCAL nRow := GetProperty(cParentForm,cControl, "CellRowFocused")
_SetToolTip(cControl,cParentForm, 'Klik rechts voor opties' )
RETURN Nil
This gives tooltip on right click ('Klik rechts voor opties') and when you click right it will show options
Let me know if this is what you want!
Posted: Mon Jun 13, 2022 7:47 pm
by Red2
Hi Serge,
Thank you for kindly supplying your segment of code. I really appreciate it.
I am now figuring out how I can apply your code.
Unfortunately I will need time to work this out because:
1) My project is based on the HMG IDE.
2) My grid control uses a .DBF file rather than an array.
I am carefully delving into this.
Thanks again for your generosity and help.
Red2
Posted: Mon Jun 13, 2022 9:05 pm
I never use grid+dbf, except when dbf is loaded into an array. This way I keep dbf free. And of course filters in order to minimise number of records and paging.
Success!
Posted: Tue Jun 14, 2022 6:06 pm
by Red2
Hi Serge,
Thank you. I really appreciate your knowledge and the code you shared.
Yes, you understood what I wanted.
I adapted your
STATIC FUNCTION Check_Grid_Events() code.
Now when a Grid row is
Right-Clicked it correctly displays the
CONTEXT MENU message that is
specific to that individual Grid row.
This is exactly what I wanted.
In testing I encounter one issue, however.
When the grid's
HEADER is Right-Clicked an
(unwanted) CONTEXT MENU appears.
It e
rroneously displays the CONTEXT MENU from the last actual Grid Row that had focus.
Apparently
laCell := GetCellClicked( "DataBrowse", "BrowseStates" )
ONLY acknowledges actual Grid data row cell focus, not a HEADER click.
Question:
What can I do in
FUNCTION Check_Grid_Events() to trap when the
HEADER is clicked?
(The Grid's
OnHeadClick event happens AFTER this
Check_Grid_Events call).
Thanks again,
Red2
Posted: Tue Jun 14, 2022 9:39 pm
Hi Red,
I am about leaving my home for a holiday for 3 weeks so at the moment I cannot help further.
I might think that best way is to check aRet := {aCellData[1],aCellData[2] content.
Good luck !
PS It is not my code! I found it somewhere in the samples or whatever...
Posted: Thu Jun 16, 2022 2:04 pm
by Red2
Thank you Serge. Have a great holiday. You have been
100% helpful!
My Question:
Can anyone with more experience suggest a way to Release/Cancel an
activated
CONTEXT MENU Definition
AFTER no MenuItem was selected?
Mi pregunta:
¿Puede alguien con más experiencia sugerir una forma de Release/Cancel una
CONTEXT MENU Definition activada DESPUÉS de que
no se seleccionó ningún MenuItem?
I see two ways to prevent the CONTEXT MENU appearing after the
Header is Right-Click.
- More complicated: Hook into the very beginning of the CONTEXT MENU event.
When it fires and a Right-Click is inside the Header Line, Cancel the event.
More promising: After the CONTEXT MENU event finishes simply Release its Definition.
This will work. My code Defines the CONTEXT MENU each time a Grid line is Right-Clicked.
At the end of my ACTION code I added:
IF ( IsControlContextMenuDefined( "BrowseStates", "DataBrowse" ) )
ReleaseControlContextMenu( "BrowseStates", "DataBrowse" )
BUT, this is sufficient
if, and ONLY if, the user actually
selects a MenuItem.
The issue: If
nothing is selected then the ACTION
never fires.
Thank you all for your kind help,
Red2
Posted: Mon Jun 20, 2022 4:24 pm
by Red2
It seems that Serge's code along with the following two additions is the best solution HMG will allow.
#1 - In the Grid's OnChange event release any CONTEXTMENU
#2 - When the CONTEXTMENU ACTION fires make sure the code finishes by releasing any CONTEXTMENU.
Altogether this displays what I want, generally.
So, on a Right-Click Check_Grid_Events() creates a row-specific CONTEXTMENU.
It will then be removed by the user's next action UNLESS the user immediately clicks
inside the Grid's Header where it will still appear (not having been removed).
Unfortunately I do not see how to eliminate this one "bug".
I am forced to accept this possibility to get a CONTEXTMENU that is specifically customized to each Grid Row.
If anyone can suggest another solution please do. I would greatly appreciate your ideas!
Thanks again,
Red2
