Estimados,
HMG da error cuando se abre una ventana child si hay una ventana modal activa.
¿Hay alguna forma de verificar que no haya una ventana modal activa antes de abrir una child?
Saludos,
Luis Vasquez.
Dear,
HMG gives error when you open a child window if there is a modal window
active.
Is there any way to verify that there is a modal window before Active
opening a child?
Greetings,
Luis Vasquez.
Ventana activa
- luisvasquezcl
Re: Ventana activa
Hi Luis Vasquez,luisvasquezcl wrote: HMG gives error when you open a child window if there is a modal window
active.
opening a child?
Try the following function:
function IsModalActive
return _HMG_SYSDATA [ 271 ]
- luisvasquezcl
Re: Ventana activa
Grigory thanks.
try with what I provided.
thank you very much
Luis Vasquez
thank you very much
Luis Vasquez
