Color for TEXT in RTF
i want to use RICHEDITBOX and assign TEXT where i use Color for different Words.
RED, GREEN , BLUE
in Help file i foundd
     <FormName>.<ControlName>.FontColor       :=  aRGBcolor | RTF_FONTAUTOCOLOR
     <FormName>.<ControlName>.FontBackColor   :=  aRGBcolor | RTF_FONTAUTOBACKCOLOR
but Property can only be used after create ...
as i have a FOR / NEXT i need "colored" RTF "String" (?) before create as i want to assign
     VALUE cText  // TRF-String ?
did somebody have a Sample :idea:
Re: Color for TEXT in RTF
Hola Jimmy y todos los del grupo... }
encontre esto para manejar archivos RTF espero les sirva
# Notes on RichText() Class for Clipper/FiveWin
1/28/97
Author: Tom Marchione
73313,3626@compuserve.com
LEGAL STUFF
All source code is Copyright (C) 1997 Thomas R. Marchione.  As a
Clipper/Fivewin user, you are granted the right to use and modify the code for
application work, provided that all file headers are kept intact, you do not
offer the source code for sale, and do not port the code to another language.
Future versions of this class may or may not be offered for public consumption
by the author.  Use the code at your own risk -- no warranties are expressed or
implied.  Etc., etc...
GETTING STARTED
If you're really curious about what this thing does, compile and run the sample
application (just look at the "BUILDRTF.BAT" batch file -- it's really simple,
if you're already a Clipper/Fivewin developer).  Then open the output file
(RTFDEMO.RTF) in Microsoft Word (personally, I haven't tested it with anything
else). If you don't have time to to compile and run the app, I've included an
unedited copy of the output file in the uploaded ZIP file.
OVERVIEW
RichText() is a class written for Clipper/Fivewin, designed to export formatted
data directly to Rich Text Format (RTF) files from within an application. The
class includes the source code, as well as Clipper command directives for
simplified xBASE implementation at the application level.
As of this writing, the class is _clearly_ a work in progress; some of the
features may not work entirely as intended, and it's fairly finicky overall.
Currently, the class implements a small subset of the RTF specification, as
taken from Microsoft documentation.  RTF is a very detailed specification, and
my intent was to provide easy access to the most basic and useful features of
RTF, including attributes such as page setup, fonts, paragraph formatting,
character formatting, headers & footers, tables, etc.  Because the basic
structure of all RTF commands is similar, the class can be expanded to include
other features, as necessary.
All of my (very much limited) testing, to date, has been done with Microsoft
Word.  I have not tried reading the output files in any other application.
Note that RichText() is different from the TRtfFile() class supplied with
Fivewin 1.9.1.  The latter provides a simple set of tools for generating
Windows help files, whereas RichText() is intended primarily as a tool for
generating special-purpose, end-user reports.  However, it would be relatively
easy to merge the capabilities of the two classes.  Since I don't own the code
to TRtfFile(), I have made no attempt to do this in this version.  I have no
idea of what's available in Fivewin 1.9.2.
WHAT IS RTF?
RTF is a Microsoft file specification for transferring formatted text between
applications.  As such, it it's a great way to move formatted database
information into word processors, in a _true_ word processing format. For those
who are interested, the RTF specification is available as a Microsoft Word
document, either from Compuserve or the Microsoft Internet site.  That document
is indispensable, if you intend to expand the capabilities of the RichText()
class.
WHAT'S THE POINT?
Occasions arise when end users would like to manipulate data in word processors.
If your end-users need to integrate output from a Clipper database application
into word-processed reports, without manually reformatting documents or writing
clumsy macros, then RTF files are an attractive, simple and nearly universal
solution.  This type of requirement is what spawned the RichText() class.
The RichText() class is not intended to be a core report generating system for
most applications, and the class will likely be a waste of time for many
developers with simple reporting requirements.  Fivewin's report class and
third-party report generators do a fine job of generating standard reports,
and my understanding is that some third party products can even generate RTF
output.  At this point, RichText() is not integrated with any other reporting
system.
So what's the point of this class?
First, it's cheap (free, in its initial incarnation).  It's a simple,
low-overhead solution.  If you're not using a big, third-party report generator
already, but only need one or two RTF-formatted outputs (maybe a form letter or
two), this is a simpler answer.
Second, it's extremely flexible.  You can produce one-of-a kind, free-form
word-processing documents (for a good example, see the sample provided with the
class).  The class is inherently oriented toward paragraphs, bullets, hanging
indents, page orientation, etc., not standard database reporting fare such as
column headers, subtotals, etc. (although you can easily dump data into
nicely-formatted tables).
Third, the output files are true word-processing files, without extraneous
spaces, carriage returns, and other "lint" that makes life difficult in a word
processing context.  If you have ever tried to pass off a flat text output file
as "word processor compatible", you'll know what I mean.  Compatible? Yes.
Usable? Hardly.
ESSENTIAL FEATURES OF RTF
For detailed information about RTF, consult the Microsoft specification,
mentioned earlier in this document.  It is also helpful to analyze the contents
of RTF files generated from word processors.  Although the xBASE layer of
RichText() makes many of the technical details transparent, it will be helpful
to clarify a few issues here.
RTF uses 7-bit ASCII characters (0-127) to represent formatting codes and data
(higher-order ASCII characters must be represented in hexadecimal, which is
handled transparently by RichText()).  The two essential formatting characters
in RTF are "\" (backslash) and "{}" (curly braces).  All formatting commands are
preceded by a backslash, and all "groups" are enclosed in curly braces.  Groups
delineate portions of a document to which combinations of formatting information
may apply.  Groups can be nested; the RTF file itself is considered a group, so
all RTF files have at least one pair of curly braces, which encloses the entire
contents of the file.
All RTF files have an RTF header (which is to be distinguished from the headers
and footers that you may place in an RTF document).  The RTF header appears at
the top of the file and contains information about fonts, colors, styles, etc.
For example, the font table within the RTF header contains a list of all of the
fonts that are used in the document.  To switch fonts later the document, an
index into this font table must be used.  A similar system is used for colors.
RichText() takes care of the RTF header for you.
An application that reads RTF files is called an RTF Viewer.  For the most part,
data items that you write to an RTF file appear within RTF Viewers in the
sequence that they were written.  However certain RTF commands implement
alternate "destinations", such as headers and footers.  RTF also supports the
"sections" that are found in Microsoft Word, with section-specific layouts and
formats.
WHERE TO GO FROM HERE
If you like the capabilities that are demonstrated in the sample, take a look at
the source code for the sample (RTFDEMO.PRG).  From there, look at the header
file (RICHTEXT.CH), and then dive into the class itself (RICHTEXT.PRG).  It's
more tedious than complicated -- if you are willing to learn a few key RTF
concepts, you'll find that most of the code is actually very simple and basic.
A word of warning -- it's very easy to break an RTF file.  Surprisingly enough,
MS-Word can throw up and die if you misplace even one seemingly innocent code.
So, if you decide to change the base class, make sure that you test each change!
So far, I have made no effort to explore the real possibilities of the class, in
terms of integrating it into more traditional reporting systems, or building
better application-level components to meet recurring, standard requirements.
If you have any ideas or suggestions, I'd love to hear them.
Have fun!
Tom
RichText.rar
(19.91 KiB) Downloaded 116 times
Thx for help.
i have change Control RICHEDITBOX to IMAGE and "build" Picture "from TEXT"
Problem was to "activate" RICHEDITBOX as it have no ONCLICK or ONDLBCLICK Event
i try some Workaround but got "strange" Error which i have not with LABEL, EDITBOX or LISTBOX before.
my Solution now seem to use IMAGE which load a PICTURE "made from TEXT"
LOCAL hBitmap := BT_BitmapCreateNew(nWidth,nHeight, WHITE )
LOCAL hDC2 := BT_CreateDC ( hBitmap, BT_HDC_BITMAP, @BTstruct2 )
LOCAL cText
   cText := "11.09.2011"
   BT_DrawText (hDC2, nRow, nCol, cText, cFontName, nFontSize, aFontColor, aBackColor, nTypeText, nAlingText, nOrientation)
   cText := "Hello World"
   aFontColor := BLACK
   aBackColor := GREEN
   nRow += 14
   BT_BitmapSaveFile (hBitmap, "DAYPIC.BMP", BT_FILEFORMAT_BMP )
   BT_DeleteDC( BTstruct2 )
   SetProperty( "Form_Month", "Label_01","PICTURE", "DAYPIC.BMP")
   FERASE("DAYPIC.BMP")
Question : how to "SET" hBitmap direct to IMAGE :idea:
AUGE_OHR wrote: Fri Sep 10, 2021 8:41 pm hi,
Hi Jimmy,
Did you tried
SetProperty( "Form_Month", "Label_01","HBITMAP", hBitmap)
See doc:
BT_HMGSetImage (cFormName, cControlName, hBitmap, lReleasePrevious)
