Icon in Column Header show sort up/down
i found in c:\MiniGUI\SOURCE\c_grid.c
//       ListView_SetSortHeader ( nHWndLV, nColumn [, nType
//                                /*0==none, positive==UP arrow or negative==DOWN arrow*/] ) -> nType (previous setting)
HB_FUNC( LISTVIEW_SETSORTHEADER )
code seems to work unter HMG 32/64 Bit
! Note : i recommend to replace LR_LOADMAP3DCOLORS with LR_CREATEDIBSECTION else Transparency / 256 Bitmap Colors do not work correct
salamandra
DBs Used: DBF, MySQL, SQL
Re: Icon in Column Header show sort up/down
Post by salamandra »
Thank you Jimmy !!
Salamandra, Brazil
