sync GRID with DBF
Posted: Mon Aug 23, 2021 12:41 am
while
does not work with GRID i need other Solution
when using GRID with ROWSOURCE for DBF it will change Property "Recno" ( NOT "Value" )
now you NEED
to sync DBF with GRID
i try to use a Thread to check if "Recno" have change while ONCHANGE does not react
but it does not work
... hm
so i use a TIMER
and this work
Question : why is Thread not working here
while
SET BROWSESYNC ONwhen using GRID with ROWSOURCE for DBF it will change Property "Recno" ( NOT "Value" )
#IFDEF Use_Browse
nRecNo := GetProperty( "XPPTEL", "Browse_1", "value")
#ELSE
nRecNo := GetProperty( "XPPTEL", "Browse_1", "RecNo")
#ENDIF
GOTO(nRecNo)---
hb_threadStart( HB_THREAD_INHERIT_PUBLIC, @Wait4Action() )Code: Select all
PROCEDURE Wait4Action()
LOCAL nRecNo := 1
STATIC xOld := 0
DO WHILE lRunning = .T.
IF USED()
IF IsControlDefined ("Browse_1", "XPPTEL")
#IFDEF Use_Browse
#ELSE
#ENDIF
IF xOld <> nRecNo
xOld := nRecNo
GOTO(nRecNo)
XPPTEL_Store()
DO EVENTS
hb_idleSleep( 1 )
ENDDO
RETURNso i use a TIMER
DEFINE TIMER internal_timer_2 INTERVAL 100 ACTION Wait4Action()Code: Select all
LOCAL nRecNo := 1
STATIC xOld := 0
IF USED()
#IFDEF Use_Browse
#ELSE
#ENDIF
IF xOld <> nRecNo
xOld := nRecNo
GOTO(nRecNo)
XPPTEL_Store()
DO EVENTS
RETURNQuestion : why is Thread not working here
