use Firefox bookmarks-YYYY-MM-DD.json
did somebody have Code to "read" Firefox *.JSON Backup File :?:
Re: use Firefox bookmarks-YYYY-MM-DD.json
Try viewtopic.php?f=15&t=5762&hilit=HBJSON3.0
read
Opening JSON Files with Notepad++
Download and install Notepad++.
Open Notepad++, click the Plugins button at the top and select Plugins Admin.
In the Plugins Admin window, search JSON Viewer and install the JSON Viewer plugin.
When prompted, click Yes. Notepad++ will exit and then restart after the plugin has finished installing.
Now, navigate to File > Open or press the CTRL + O buttons and select the JSON file you want to open.
Once the file is opened, go to Plugins > JSON Viewer and select Format JSON. Then again go to Plugins > JSON Viewer and select Show JSON Viewer.
You can now view and edit the contents of the JSON file.
in firefox menu file, OPEN, SEARCH THE json file and look at its structure
2021-08-20 21_27_29-Window.png (29.54 KiB) Viewed 4596 times
If you want to read it from HMG, use SQLite library!
Yes! SQLite can convert JSON to tables!
Rathinagiri wrote: Sat Aug 21, 2021 4:34 am If you want to read it from HMG, use SQLite library!
Yes i have "think" about "read" SQlite Table "direct" ... but it need to "learn" how it work under HMG
while Daniel "remind" me that JSON have a "Format-Structure" i user FileIO and search for "Delimiter"
each "Row" start with
   cSeek := "{"+CHR(34)+"guid"+CHR(34)+":"
and "End" with
   nEnde := hb_AT( "}", cBuffer , nPosi)
as i only need URI and Description i search for
   cSeek := CHR(34)+"uri"+CHR(34)+":"
now i got it so far and wanted to transfer it to DBF ... but how LEN ...
nMaxTXT : 142
nMaxURI : 650
so URI will not fit into Type "C", or :?:
character field maybe longer than 255 character, is it problem?
jairpinho
Post by jairpinho »
hello see if it helps
#include "hbclass.ch"
 Clase que define los methods que seran necesarios sobrecargar
 para darle funcionalidad */
CLASS BaseService
   // La data uValue inicialmente es un array. Lo he dejado de esta manera
   // pensando más en devolver una lista que un objeto JSON.
   DATA uValue
   DATA lError INIT .F.
   METHOD New()                    CONSTRUCTOR
   METHOD getError()              INLINE ::lError
   METHOD GetJSON()
   METHOD getBydId()
   METHOD findAll()
   METHOD DeleteBydId()
   METHOD Create()
   METHOD Modify()
END CLASS
METHOD New()  CLASS BaseService
   ::uValue := {}
   RETURN Self
 Por defecto, los methods , si no estan sobreescritos, el valor de retorno
 dará un error 501 Not Implemented
METHOD getBydId() CLASS BaseService
   RETURN ( ::lError := .T.,  USetStatusCode( 501 ) )
METHOD findAll()  CLASS BaseService
METHOD DeleteBydId() CLASS BaseService
METHOD Create() CLASS BaseService
METHOD Modify() CLASS BaseService
METHOD GetJSON() CLASS BaseService
   RETURN if( ::uValue != NIL, hb_jsonEncode( ::uValue, .T. ), NIL )
Jair Pinho
HMG ALTA REVOLUÇÃO xBASE
HMG xBASE REVOLUTION HIGH
http://www.hmgforum.com.br
