HMG with Edge WebView2
After much trial and error, and fight a little with the parameters of hbmk2 I managed to create a demo of HMG with Edge WebView2.
It is not much information on Edge WebView2 compiled with GCC/MinGW on the Internet maybe because most people use Visual Studio to build WebView2 applications. Most of the samples use MSVC ++ and a few of Microsoft's own compiler C++ classes.
I hope you enjoy!
hmg_webview2.zip
(2.07 MiB) Downloaded 313 times
Re: HMG with Edge WebView2
try to run Sample and got Error
Windows Version 10.0.19044.1165
Microsoft Edge Version 92.0.902.73 (Offizielles Build) (32-Bit)
AUGE_OHR wrote: Tue Aug 17, 2021 2:54 am hi,
Hola Dr. Soto, Saludos...
Igual conmigo !
Windows 10 Pro 21H1 19043.1165
Microsoft Edge Versión 92.0.902.73 (Compilación oficial) (64 bits)
Al compilarlo, despliega esto:
G:\AGL\Desarrollos\Pruebas\hmg_webview2>call build_cpp.bat test_webview2.prg -L./WebView2/Win32 -lWebView2Loader -I./WebView2/include
Harbour 3.2.0dev (r2011030937)
Copyright (c) 1999-2020, https://harbour.github.io/
In file included from test_webview2.prg:51:
G:/AGL/Desarrollos/Pruebas/hmg_webview2/WebView2/include/WebView2.h:19: warning: ignoring #pragma warning [-Wunknown-pragmas]
19 | #pragma warning( disable: 4049 ) /* more than 64k source lines */
test_webview2.prg: In instantiation of 'HRESULT Null_QueryInterface(T*, const IID&, void**) [with T = ICoreWebView2CreateCoreWebView2EnvironmentCompletedHandler; HRESULT = long int; IID = _GUID]':
test_webview2.prg:107:1: required from here
test_webview2.prg:82:57: warning: unused parameter 'This' [-Wunused-parameter]
test_webview2.prg:82:70: warning: unused parameter 'riid' [-Wunused-parameter]
test_webview2.prg:82:83: warning: unused parameter 'ppvObject' [-Wunused-parameter]
test_webview2.prg: In instantiation of 'ULONG Null_AddRef(T*) [with T = ICoreWebView2CreateCoreWebView2EnvironmentCompletedHandler; ULONG = long unsigned int]':
test_webview2.prg:87:47: warning: unused parameter 'This' [-Wunused-parameter]
test_webview2.prg: In instantiation of 'ULONG Null_Release(T*) [with T = ICoreWebView2CreateCoreWebView2EnvironmentCompletedHandler; ULONG = long unsigned int]':
test_webview2.prg:92:48: warning: unused parameter 'This' [-Wunused-parameter]
test_webview2.prg: In instantiation of 'HRESULT Null_QueryInterface(T*, const IID&, void**) [with T = ICoreWebView2CreateCoreWebView2ControllerCompletedHandler; HRESULT = long int; IID = _GUID]':
test_webview2.prg:120:1: required from here
test_webview2.prg: In instantiation of 'ULONG Null_AddRef(T*) [with T = ICoreWebView2CreateCoreWebView2ControllerCompletedHandler; ULONG = long unsigned int]':
test_webview2.prg: In instantiation of 'ULONG Null_Release(T*) [with T = ICoreWebView2CreateCoreWebView2ControllerCompletedHandler; ULONG = long unsigned int]':
g:/agl/hmg/3.5/mingw/bin/../lib/gcc/i686-w64-mingw32/9.3.0/../../../../i686-w64-mingw32/bin/ld.exe: warning: resolving _CreateCoreWebView2EnvironmentWithOptions@16 by linking to _CreateCoreWebView2EnvironmentWithOptions
Use --enable-stdcall-fixup to disable these warnings
Use --disable-stdcall-fixup to disable these fixups
1) My .exe not work?
2) Try change this line in C code:
HRESULT result = CreateCoreWebView2EnvironmentWithOptions( nullptr, TStrToWStr(szDataPath).c_str(), nullptr, &handler );
For this line:
HRESULT result = CreateCoreWebView2EnvironmentWithOptions( nullptr, nullptr, nullptr, &handler );
srvet_claudio wrote: Tue Aug 17, 2021 4:05 am Hi,
Así como viene el .exe que envió despliega lo siguiente.
For this line:
Resulta el mismo mensaje al volverlo a compilar ya modificado...
There is not much information on webview2 with c ++ and the error answers are very ambiguous in many cases. Please compile this new file to see if we can better capture the error that occurred.
new prg test_webview2.zip
(3 KiB) Downloaded 218 times
srvet_claudio wrote: Tue Aug 17, 2021 5:59 pm There is not much information on webview2 with c ++ and the error answers are very ambiguous in many cases. Please compile this new file to see if we can better capture the error that occurred.
Aquí va Dr. Soto...
In file included from test_webview2.prg:54:
test_webview2.prg:110:1:   required from here
test_webview2.prg:85:57: warning: unused parameter 'This' [-Wunused-parameter]
test_webview2.prg:85:70: warning: unused parameter 'riid' [-Wunused-parameter]
test_webview2.prg:85:83: warning: unused parameter 'ppvObject' [-Wunused-parameter]
test_webview2.prg:90:47: warning: unused parameter 'This' [-Wunused-parameter]
test_webview2.prg:95:48: warning: unused parameter 'This' [-Wunused-parameter]
test_webview2.prg:123:1:   required from here
Hi Andres,
The information on the internet is scarce, but the problem seems to be with the runtime version you have of webview2, please update your runtime version from this Microsoft link:
https://go.microsoft.com/fwlink/p/?LinkId=2124703
srvet_claudio wrote: Tue Aug 17, 2021 10:42 pm Hi Andres,
Solucionado Dr. Soto, muchas gracias por su ejemplo y ayuda !
this is a slightly improved version with more information to detect and solve errors in webview2 runtime.
hmg_webview2_version02.zip
(2.08 MiB) Downloaded 334 times
