Dear experts:
I have defined a "modal" window where I perform the basic maintenances tasks of a table (new, modify, last, first, delete, etc.). This is working fine.
I am having some compiling problems when I call a procedure and in this procedure I just want to obtain some data from the user, using the TextBox control. Do I need to define another window just to obtain this data? I do not want to close or lose my original window.
Thank you very much,
Mr. Clinker
Uruguay
Confused about windows definition
Re: Confused about windows definition
Hi Mr. Clinker,
New window need not be defined. Controls can be defined inside a procedure even though the window is defined in a different procedure previously.
So, even after the window is active, we can define a control.
sample1.prg
# include "minigui.ch"
define window x at 0,0 width 100 height 100 modal
end window
x.center
x.activate
sample2.prg
declare window x
define textbox t1
row 10
col 10
width 80
parent x
end textbox
- luisvasquezcl
you can use Inputbox() too... see this
Function ReadData
local xVar := ""
xvar = Inputbox('Find','Input data to find', xVar)
Return xVar
regards,
Luis Vasquez.
PD. Excuse me my english i'm spanish speaking.
Function ReadData
local xVar := ""
Return xVar
regards,
Luis Vasquez.
Simple and neat solution Luis Vasquez. Thanks.
