Harbour MiniGUI IDE 2.5.8
Posted: Wed Aug 20, 2008 10:36 pm
by Roberto Lopez
Harbour MiniGUI IDE 2.5.8:
English:
- Modified: 'New Project' command automatically creates a new main module,
main form, and opens them.
- Fixed: Misc bugs.
Español:
- Modificado: El comando 'Nuevo Proyecto' crea automáticamente un nuevo
módulo principal, una ventana principal y los abre.
- Solucionado: Misc bugs.
Re: Harbour MiniGUI IDE 2.5.8
Posted: Fri Aug 22, 2008 5:26 pm
Thanks Roberto
'New Project' command automatically creates a new main module, main form, and opens them.
IMHO this enhancement doesn't made easy the usage for whose works "IDE only".
Also, when started IDE via "file assosiation" (by clicking a .hpj file); "Open Project" command (from file menu, toolbar or F2 key) does not work as before. Don't open "Open Project" window, reopen active or last used project file. This may be an intention; but doesn't made easy the usage for me.
Posted: Fri Aug 22, 2008 8:03 pm
by Roberto Lopez
esgici wrote:Thanks Roberto
IMHO, that new project command creates a main program that calls a main window (automatically created too) is a very good thing.
Without this new behavior, the new HMG user must know that a Load Window and Activate Window commands are required, that a new window of type 'Main' must be created and some other minor things. For experienced users, it is good too. It is a nice starting kick for a new project (I'm using and I like it
Regarding 'associaton' I've not made anything about that for this version (at least intentionally). I'll check it.
Roberto.
Posted: Fri Aug 22, 2008 8:13 pm
by Roberto Lopez
I've checked and understood the problem.
THIS IS A HUGE BUG!!!
I'll fix it ASAP.
Thanks for the report.
Roberto.
Posted: Fri Aug 22, 2008 8:43 pm
by Roberto Lopez
I'll fix it ASAP.
Roberto.
FIXED IN 2.5.8a!
Roberto.
