How to create hmgmysql library in 64 bits
Hello,
How shall I create hmgmysql library in 64 bits?
I am getting this error:
C:/HMG/lib-64\libhmgmysql-64.a(hmgmysql.o):hmgmysql.c:(.data+0x70): undefined reference to `HB_FUN_TMYSQLSERVER'
Thanks in advance :-)
Re: How to create hmgmysql library in 64 bits
Hi Sudip
Mira si te puede servir esta versión
See if this version can help you
Regards /Saludos /Salam
libhmgmysql-64.zip
(2.2 KiB) Downloaded 737 times
Thanks a ton Mustafa. I shall try and confirm :-) :-) :-)
Hello Mustafa,
I am getting the same problem. Shall I need to change the configuration?
Screenshot 2021-08-10 111011.jpg (102.16 KiB) Viewed 25170 times
Thanks a lot :-)
gisjr134
Post by gisjr134 »
Hello Supid ,
in my project i use harbour 64 bits , wich i downloaded and made a build of it. There is a folder called Hbmysql , wich has a file called HbMysql.Hbc . I Use That File in my Projetct ,as Described bellow.
echo Debug Compilacao.
Build64 /n /b SisDbHmg.Hbp SisDbHmg.Hbc hbmySql.Hbc
in Hmg\lib64 folder there is a libhbmysql.a , wich was created when
harbour64 was builded.
i Dont know if there is some other way To use Mysql 64 bits library , but This way i Told you It works fine for me.
I hope This information will be useful for you.
Hello Gisjr134,
Thanks for your help.
I think I should create hbmysql.a library in C:\HMG\HARBOUR-64\lib\win\mingw64 folder.
I copied HBMYSQL folder from C:\HMG\HARBOUR\CONTRIB to C:\HMG\HARBOUR-64\CONTRIB FOLDER. But I couldn't create that library.
Can anyone please help?
