Post
by AUGE_OHR »
i have to learn about Difference of HMG and Xbase++ CLASS Code Syntax
METHOD setTabstops() VIRTUAL
METHOD itemMarked( ... ) SETGET
what does VIRTUAL mean
under Xbase++ i have ACCESS ASSIGN. is that the same like SETGET
"where" can i read more about HMG CLASS Syntax
Post
by Rathinagiri »
I think there is nothing called HMG CLASS syntax. It is Harbour Class only.
I think you can get more info from
https://harbour.github.io/doc/harbour.html#class-cmd
Post
by Rathinagiri »
As per Harbour Doc:
VIRTUAL Methods that do nothing. Useful for Base classes where
the child class will define the method's behavior, or when you are first creating and testing a Class.
Post
by gfilatov »
AUGE_OHR wrote: ↑Thu Jul 22, 2021 12:35 am
Yes, it is.
Example code:
CLASS XbpReg
/*ACCESS ASSIGN*/ METHOD Standard SETGET
/*ACCESS ASSIGN*/ METHOD ReadBinType SETGET // get/set ::cReadBinaryTypeAs
/*ACCESS ASSIGN*/ METHOD SaveStringType SETGET // get/set ::cSaveStringTypeAs
