HMG Extended Edition version 21.07 is published
Hi Friends,
Edition.
Here's a breakdown of some of the modifications in the build 21.07.
* Minor correction in the method VarPut() of the Harbour TGet class.
It fixes the following problem: GetBox control do not execute the
'On Change' procedure after assigning a value at the calling of
the function SetProperty ( Form, GetBox, 'Value', xValue ).
* Fixed a missing PICTURE clause handling in the BROWSE control at the
alternative syntax.
* A Star Rating is a type of rating question that allows users to rank
attributes on a 5- or 10-point scale represented with stars.
It is a 5-point matrix question, but instead of radio buttons or
checkboxes, stars are used to represent it.
Syntax:
@ <row>,<col> RATING <name> [ OF <parent> ] ;
[ WIDTH <w> ] ;
[ HEIGHT <h> ] ;
[ PICTURE { "image1.png", "image2.png" } ] ;
[ FROM RESOURCE ] ;
[ STARS <count> ] ;
[ RATE <value> ] ;
[ SPACING <space> ] ;
[ ON CHANGE <change> ] ;
[ TOOLTIP <tooltip> ] ;
[ BORDER ] ;
[ VERTICAL ] ;
[ READONLY ]
There is the read/write 'Value' property for this control.
* Added a new method 'GetArray' for retrieving of array for ComboBox,
Grid, ListBox at runtime.
* Added new command for managing delimiter in the function HMG_Alert():
SET ALERT EOL [ NORMAL | STANDARD ]
The default is STANDARD: '|' symbol for Greek language and ';' -
for others.
* Added the disabled 'Checked On' state in the SWITCHER control.
It is now a fully functional Windows 10 control.
* INI file - added the following new commands:
- GET BEGIN COMMENT TO <uVar>;
- GET END COMMENT TO <uVar>;
- SET BEGIN COMMENT TO <uVal>;
- SET END COMMENT TO <uVal>;
and the corresponding functions:
- GetBeginComment() and SetBeginComment() to get/set a comment at
the first line of an INI file;
- GetEndComment() and SetEndComment() to get/set a comment at the
last line of an INI file.
* Updated DO REPORT command:
- added the ability to define the fontname used to print the report;
- implementation some internationalization of the few messages that
are displayed during the report creation (please, add translation
in your language).
* The function AlertRetryCancel() is localized now.
* Updated HMGS-IDE v.1.4.4.4, GraphPlus and Shell32 libraries.
* Added the new interesting samples and updated some examples.
There are the separate versions of the MiniGUI library for ANSI and
UNICODE characters.
A setup of the ANSI build 21.07 for Borland C++ 5.8.2 is published at
the following URL:
There is also an extra donationware Minigui Ex build for the
Embarcadero C++ 10.2 ‘Tokyo’ compiler.
[MiniGUI Team]
Anand
Re: HMG Extended Edition version 21.07 is published
Post by Anand »
Thanks for the update, Grigory
Anand
salamandra
DBs Used: DBF, MySQL, SQL
Post by salamandra »
Hi Grigory,
Thank you very much for this new release (and for your efforr).
Salamandra, Brazil
JALMAG
DBs Used: DBF, MariaDB
Post by JALMAG »
Thanks Grigory!!
Congratulation Grigory.
BEST regards
Thanks for your feedback.
Please note that there are also the MiniguiEx build 21.07 for the following freeware C-compilers:
- Embarcadero C++ 7.30 for Win32;
- MinGW 32-bit (GCC with MCF thread model, built by LH_Mouse.) 11.1.1 20210708;
- MinGW 64-bit (MinGW-W64 x86_64-posix-seh, built by Brecht Sanders) 11.1.1 20210710;
- Microsoft Visual C++ 19.29.30037 (32/64-bit).
The above packages are available for the all donators by their request 8-)
I've uploaded the updated setup of the build 21.07 for Borland C++ 5.8.2 at
Whatsnew:
2021/07/30: HMG Extended Edition version 21.07 (Update 1).
* Fixed: Correction of the vertical position of the page titles for the
font's size more than 24 pt in the ownerdraw colored TAB.
Requested by Verchenko Andrey <verchenkoag/at/gmail.com>.
(see demo.prg in folder \samples\Basic\TAB)
* New: Added the new command to create a link file (short-cut).
Syntax:
CREATE LINK FILE <Linkfile> ;
TARGETFILE <Targetfile> ;
[ TARGETARGS <Targetargs> ] ;
[ DESCRIPTION <Description> ] ;
[ SHOWMODE <Showmode> ] ;
[ [ WORKING ] DIRECTORY <Curdir> ] ;
[ ICON [ LOCATION ] <Iconfile> ] ;
[ ICONINDEX <Iconindex> ] ;
[ RESULT [ TO ] <nSuccess> ]
where
Linkfile - the file name of the actual link file;
Targetfile - the file name of the link's target;
Targetargs - the command line arguments of the link's target;
Description - the description of the link's target;
Showmode - the ShowWindow() constant for the link's target;
Curdir - the working directory of the active link;
Iconfile - the file name of the icon file used for the link;
Iconindex - the index of the icon in the icon file.
This is based on an example in MSDN.
(see demo in folder \samples\Basic\CreateLink)
* Updated: Header file i_hmgcompat.ch for compatibility with Official HMG:
- added two pseudo-functions GetControlFontHandle( Control, Form )
and GetControlFontHandleByIndex( idx ).
(see demo in folder \samples\Applications\GenPassword)
* Updated: HbSQLite3 library:
- update for using SQLITE3 version 3.37.0dev (from 3.36.0).
Contributed by Grigory Filatov <gfilatov@inbox.ru>.
* Updated: 'Registry Test' sample:
- added the auxiliary function SetWallPaper().
(see in folder \samples\Basic\REGISTRY)
* Updated: 'Link Executor' sample:
- updated for compatibility with Windows 10.
(see in folder \samples\Applications\LINK_EXECUTOR)
Thanks for your attention and support. :arrow:
[MiniGUI Team]
Whatsnew:
2021/08/12: HMG Extended Edition version 21.07 (Update 2).
* New: Added the useful function HMG_FileCopy() to copy a file to a new file.
Syntax:
HMG_FileCopy( <cSourceFile>, <cTargetFile>, [<nBuffer>], [<bEval>] )
--> lSuccess
where
<cSourceFile> is the name of the source file including the path and
the extension;
<cTargetFile> is the name of the target file including the path and
the extension;
<nBuffer> is the buffer size in bytes. The default is 8192 bytes;
<bEval> is the code block which is executed with the percentage
of the file copied.
This function returns false if an errors occurs, otherwise,
it returns true.
Based upon a contribution of Jacek Kubica <kubica/at/wssk.wroc.pl>
(see demo in folder \samples\Basic\Filecopy)
* Updated: Pacified a C-warning in the MiniGUI core for compatibility
with the new Pelles C 11.0 (64-bit).
* New: The SELECTOR library source code (see in folder \Source\SELECTOR).
Based upon a code of Janusz Piwowarski for Clipper.
(see demo in folder \samples\Basic\Charts_3)
* Updated: Adaptation FiveWin Class TSBrowse 9.0 in HMG:
- added the new variable :bDrawCell in the TSColumn class.
This codeblock will executed in the methods DrawLine() and
DrawSelect() before calling the method TSDrawCell().
Suggested and contributed by Sergej Kiselev.
* New: 'Registry class for Xbase++ usage' sample.
Based upon a contribution of HMG user Jimmy.
Adapted for Minigui Extended by Grigory Filatov <gfilatov@inbox.ru>
(see in folder \samples\Basic\RegClass)
* New: 'Tab Control with OOP' sample.
Contributed by Sergej Kiselev and Verchenko Andrey
(see demo3.prg in folder \samples\Basic\TAB)
[MiniGUI Team]
Please note that there are also the MiniguiEx build 21.07 for the following MinGW GNU C compilers:
- MinGW 32-bit (GCC with MCF thread model, built by LH_Mouse.) 11.2.1 2021-08-09;
- MinGW 32-bit (MinGW-W64 i686-posix-dwarf, built by Brecht Sanders) 11.2.0;
- MinGW 64-bit (MinGW-W64 x86_64-posix-seh, built by Brecht Sanders) 11.2.0;
Anand
Post by Anand »
Anand
