Is_Date() function for strings in mutiple possible formats
HGAutomator
Post by HGAutomator »
Is there an IS_Date() function, other than the standard one which determines if a variable is a date object?
I'm looking for something that can intelligently determine that a string could be a date, by analyzing whether it fits an mm/dd/yyyy or yyymmdd or other potential date formats.
In a sense, I'm really trying to determine if a string can NOT be a date.
Claudio Ricardo
DBs Used: DBF, MySQL, MariaDB
Re: Is_Date() function for strings in mutiple possible formats
Post by Claudio Ricardo »
Hi... Maybe:
Function Is_Date (xParam)
Return Iif ( ValType ( xParam ) == "D", .T., .F.)
HGAutomator
Thanks Claudio, but we're not looking at date variables. We're looking at strings that might be convertible to a date variable. Or rather, I'm looking at strings that can't possibly be converted to a date variable.
I need to determine whether a variable might contain a string date, or whether is obviously cannot. So the string "01012010" might refer to a date in the forms mmddyyyy or ddmmyyyy ; but the string "helloworld" or "31201313" cannot be dates.
I'm pretty sure I've seen something like this before, althought it might not have been Harbour.
Claudio Ricardo wrote: Thu Jul 08, 2021 7:24 pm Hi... Maybe:
wistong
Post by wistong »
Hola,
Prueba con :
dVar := "25-15-2021"
IF EMPTY( CTOD(dVar))
// Fecha Inválido
// Fecha válida
ENDF
Ayuda :
CTOD()
Convert a date string to a date value
Syntax
CTOD(<cDate>) --> dDate
Arguments
<cDate> is a character string consisting of numbers representing the
month, day, and year separated by any character other than a number.
The month, day, and year digits must be specified in accordance with the
SET DATE format. If the century digits are not specified, the century
is determined by the rules of SET EPOCH.
Returns
CTOD() returns a date value. If <cDate> is not a valid date, CTOD()
returns an empty date.
HGAutomator
Thanks I'm familar with the date functions, but they all assume that the date string is in a specific format. I'm looking for a function that covers all possible formats. Also, it doesn't need to convert the string to a date ; it just needs to determine that it's IMPOSSIBLE to convert the string to a date.
So it would have to cover all possible date formats, regardless of the state of SET DATE or EPOCH.
Anyway, I'm searching through some of my old code, non-clipper/harbour. I'm nearly certain that this was done, somewhere.
If not, I'll build it from scratch.
wistong wrote: Thu Jul 08, 2021 8:01 pm Hola,
Prueba con :
// Fecha Inválido
// Fecha válida
ENDF
Ayuda :
CTOD()
Syntax
Arguments
Returns
se deberia usar expresiones regulares para saber si una fecha es correcta en diferenes formatos.
ej
1-4-94
01/04/94
01-04-1994
etc...
http://www.hmgforum.com/viewtopic.php?t=3382
Claudio Ricardo
Hola...
Se complica aún más, ya que necesita que sea independiente del Set Date... Nosotros usamos French o German "ddmmyyyy"
pero si lo ingresan como USA "mmddyyyy" o Japan "yyyymmdd" y sin Set Century On es "yy" (año en dos digitos)
Por ejemplo 101112 puede ser valido como 10 de noviembre de 2012 o 11 de octubre de 2012 o 12 de noviembre de 2010 respectivamente :(
HGAutomator
Thanks Claudio,
For the file that we're analyzing, we don't have to worry about formats like
November 12, 2010
It'll be just digits ; or digits & slashes ; or digits & dashes.
Claudio Ricardo wrote: Fri Jul 09, 2021 7:04 am Hola...
I used to need something similar that you ask. Maybe it will be helpful.
PROCEDURE Main()
	msgdebug (IsStringValidDate( "" ) )		//.F.
	msgdebug (IsStringValidDate( "30-02-1990" ))	//.F.
	msgdebug (IsStringValidDate( "01/02/2011" ), CheckStringValidDate( "01/02/2011" ))	//.T.
	msgdebug (IsStringValidDate( "2001\02\20" ))	//.T.
	msgdebug (IsStringValidDate( "12.20.2011" ))	//.T.
	msgdebug (IsStringValidDate( "12-20-11" ))	//.T.
	msgdebug (IsStringValidDate( "12.40.2011" ))	//.F.
	msgdebug (IsStringValidDate( "12.2011.20" ))	//.T.
	msgdebug (IsStringValidDate( "12402011" ), CheckStringValidDate( "12402011" ) )	//.T.  => 1240.20.11, 12.11.4020, 11.12.4020
	msgdebug (IsStringValidDate( "12402011",  hb_CtoD( "01/01/1990" , "dd/mm/yyyy" ) /* FromDate */ ,  hb_CtoD( "31/12/2050" , "dd/mm/yyyy" ) /* ToDate */ ))	//.F.
	msgdebug (IsStringValidDate( "310210" ), CheckStringValidDate( "310210" ) )	//.T.  => 31.10.1902, 1931.02.10, 1931.10.02
	msgdebug (IsStringValidDate( "310210",  hb_CtoD( "01/01/1990" , "dd/mm/yyyy" )  /* FromDate */ ,  hb_CtoD( "31/12/2050" , "dd/mm/yyyy" ) /* ToDate */ ))	//.F.
	msgdebug (IsStringValidDate( "12@40@2011" ))	//.F.
	msgdebug (IsStringValidDate( "12x40x2011" ))	//.F.
	msgdebug (IsStringValidDate( 1111 ))		//.F.
	msgdebug (IsStringValidDate( .F. ))		//.F.
	msgdebug (IsStringValidDate( ))			//.F.
Function IsStringValidDate( cDate, dRangeFrom, dRangeTo )
Local lValidDate := Len ( CheckStringValidDate( cDate, dRangeFrom, dRangeTo ) ) > 0
RETURN lValidDate
Function CheckStringValidDate( cDate, dRangeFrom, dRangeTo  )
Local cSep:=".-/\ ", cDateCheck
Local i, j, nInsPos
Local isSep := .F.
Local aDateFormats:={ "dd/mm/yyyy", "dd/mm/yy",;
		      "mm/dd/yyyy", "mm/dd/yy", ;
		      "yyyy/mm/dd", "yy/mm/dd", ;
		      "yyyy/dd/mm", "yy/dd/mm", ;
		      "mm/yyyy/dd", "mm/yy/dd", ;
		      "dd/yyyy/mm", "dd/yy/mm" }, ;
      aTokens, aDates :={}
Local dDate
Default cDate := ""
Default dRangeFrom := CToD( "" ), dRangeTo := hb_CtoD( "31/12/9999" , "dd/mm/yyyy" )
IF !hb_isChar ( cDate )
	Return aDates
FOR i:=1 TO Len ( cDate )
	IF Substr( cDate, i, 1 ) $ cSep
		isSep := .T.
	ELSEIF !IsDigit( Substr( cDate, i, 1 ) )
		Return aDates
NEXT i
FOR i:=1 TO Len ( aDateFormats )
	IF !isSep
		aTokens := hb_Atokens ( aDateFormats [i], "/" )
		cDateCheck := cDate
		nInsPos := 0
		FOR j := 1 TO Len ( aTokens ) - 1
			nInsPos += Len( aTokens [j]) + 1
			cDateCheck := Stuff(cDateCheck, nInsPos, 0, "/")
		NEXT j
		cDateCheck := cDate
	dDate := hb_CtoD( cDateCheck , aDateFormats [i])
	IF !EMPTY( dDate ) .AND. dDate >= dRangeFrom .AND. dDate <= dRangeTo
		IF ASCAN ( aDates, dDate ) = 0
			AADD ( aDates, dDate )
NEXT i
RETURN aDates
HGAutomator
Perfect, edk. Thanks.
edk wrote: Fri Jul 09, 2021 10:37 am I used to need something similar that you ask. Maybe it will be helpful.
PROCEDURE Main()
RETURN lValidDate
Local i, j, nInsPos
Local isSep := .F.
Local dDate
Default cDate := ""
	Return aDates
		isSep := .T.
		Return aDates
NEXT i
	IF !isSep
		cDateCheck := cDate
		nInsPos := 0
		NEXT j
		cDateCheck := cDate
NEXT i
RETURN aDates
