This usage of DEFAULT
Red2
Post by Red2 »
Question: What exactly does "DEFAULT" do/mean in the following?
// SourceFiles, convert Array to String
DEFAULT acFiles TO HB_UCHAR( 0 )
In this example what does DEFAULT do to the (array) variable acFiles?
Unfortunately I have not found any explination of this usage in the HMG help file.
Thank you for your kind help!
Re: This usage of DEFAULT
if you pass a Parameter it is "expect" that it have a Value else it can crash
FUNCTION Dummy(a)
? a    // -> crash when have no Value
i you have a "default" Value you must not pass Parameter
#include "Common,ch"
FUNCTION Dummy(a)
   DEFAULT a TO "hello world"
? a    // -> does not crash
Red2
Post by Red2 »
Vielen Dank! I really appreciate your prompt and kind assistance.
