Limit of SHELLFILEOPERATION ?
i use SHELLFILEOPERATION in HBFM to Copy/Move/Delete Files/Folder and it work fine
now i use same Code for "Backup" and it work with "some Files" but fail when have 30000 :o
is there a Limit of SHELLFILEOPERATION :?:
i got FullPathNameW from "Everything" and store it in Array
i pass Array to Function ShellFiles() which made a "large String" ( LIMIT :?: )
Code is from c:\MiniGUI\SOURCE\shell32\Shell32.prg
FUNCTION ShellFiles( hWnd, acFiles, acTarget, nFunc, fFlag )
LOCAL cTemp
LOCAL cx
LOCAL lRet := .F.
LOCAL ccFiles, ccTarget
   // Parent Window
   IF EMPTY( hWnd )
      hWnd := GetActiveWindow()
   // Operation Flag
   IF nFunc == NIL
      nFunc := FO_DELETE
   // Options Flag
   IF fFlag == NIL
      fFlag := FOF_ALLOWUNDO
   // SourceFiles, convert Array to String
   DEFAULT acFiles TO CHR( 0 )
   IF VALTYPE( acFiles ) == "A"
      cTemp := ""
      FOR cx := 1 TO LEN( acFiles )
         cTemp += acFiles[ cx ] + CHR( 0 )
      ccFiles := cTemp
   ccFiles += CHR( 0 )
   // TargetFiles, convert Array to String
   DEFAULT acTarget TO CHR( 0 )
   IF VALTYPE( acTarget ) == "A"
      cTemp := ""
      FOR cx := 1 TO LEN( acTarget )
         cTemp += acTarget[ cx ] + CHR( 0 )
      ccTarget := cTemp
   ccTarget += CHR( 0 )
   // now call SHFileOperation
   lRet := ShellFileOperation( hWnd, ccFiles, ccTarget, nFunc, fFlag )
RETURN lRet
#pragma BEGINDUMP
#include <windows.h>
#include "hbapi.h"
HB_FUNC ( SHELLFILEOPERATION )
   SHFILEOPSTRUCT sh;
   sh.hwnd   = (HWND) hb_parnl(1);
   sh.pFrom  = hb_parc(2);
   sh.pTo    = hb_parc(3);
   sh.wFunc  = hb_parnl(4);
   sh.fFlags = hb_parnl(5);
   sh.hNameMappings = 0;
   sh.lpszProgressTitle = NULL;
   hb_retnl( SHFileOperation (&sh) );
#pragma ENDDUMP
Re: Limit of SHELLFILEOPERATION ?
AUGE_OHR wrote: Fri Jul 02, 2021 7:08 am hi,
Hi Jimmy,
Please note that the above C-code was NOT updated for the UNICODE charset which you are used.
:o
gfilatov wrote: Fri Jul 02, 2021 7:32 am Please note that the above C-code was NOT updated for the UNICODE charset which you are used.
do you mean this
#pragma BEGINDUMP
#include "HMG_UNICODE.h"
#include "hbapi.h"
   SHFILEOPSTRUCT sh;
   sh.hwnd   = ( HWND ) HMG_parnl( 1 );
   sh.pFrom  = HMG_parc(2);
   sh.pTo    = HMG_parc(3);
   sh.wFunc  = HMG_parnl(4);
   sh.fFlags = HMG_parnl(5);
   HMG_retnl( SHFileOperation (&sh) );
#pragma ENDDUMP
it does produce same Problem ...
AUGE_OHR wrote: Fri Jul 02, 2021 5:58 pm
do you mean this
#pragma BEGINDUMP
#include "hbapi.h"
   SHFILEOPSTRUCT sh;
#pragma ENDDUMP
No.
I means
#pragma BEGINDUMP
#include "hbapi.h"
   SHFILEOPSTRUCT sh;
#pragma ENDDUMP
:idea:
gfilatov wrote: Fri Jul 02, 2021 6:14 pm No.
I means
i have take your Code and it make same Problem : SHELLFILEOPERATION does open but close after < 1 Sec :(
i can "copy" hole Directory with > 10000 Files but it seems i can´t "copy" 10000 "single Files"
i got those Files with "A" Attribute from "fresh" installed C:\HMG35
it work when have less File ... not sure how much.
i will try to make a Sample (without "Everything" )
found out that it have to do with OS Error 2 when run SHELLFILEOPERATION
2 ERROR_FILE_NOT_FOUND The system cannot find the file specified.
this is when Filename have "German Umlaut" like "Verknüpfung" ( = Shortcut )
hm ... i can "copy" these Files in HBFM ... and it is the "same" Code
my Xbase++ Version use ANSI and, as i know, SHELLFILEOPERATION will use "A" or "W" depend on "shellapi.h"
how can i be sure to use "W" Version under HMG
LOCAL nCountry := HB_bitAND( GETKEYBOARDLAYOUT(), 0xFFFF )
   SET EPOCH TO YEAR( DATE() ) - 50
   SET CENTURY ON
   IF nCountry = 1031
      SET LANGUAGE TO GERMAN
      //    SET CODEPAGE TO GERMAN
      SET DATE GERMAN
      SET LANGUAGE TO ENGLISH
      //    SET CODEPAGE TO ENGLISH
      SET DATE AMERICAN
   // use UTF8 -> "W" instead of "A" API Function
   SET( _SET_CODEPAGE, "UTF8" )
i got it run under 32 Bit ... but i´m confused
now i use
   IF nCountry = 1031
      SET DATE GERMAN
      SET DATE AMERICAN
   // SET( _SET_CODEPAGE, "UTF8" )
in my UNICODE IDE and tell "Everything" to use "A" API Function
Result is send to ShellFileOperation() and it work :)
i did same with DIRECTORY() and it also work fine
so i can use "A" API Function in UNICIDE-IDE, or is it only for Shell Function :?:
new Problem ... :cry:
32 Bit App Version work fine, also on 64 Bit OS
64 Bit App Version "seems" to work ...
but ShellFileOperation() fail with "big" Number of Files
DE_ERROR_MAX 0xB7 MAX_PATH was exceeded during the operation.
what does this Message mean :idea:
i do try to "test" LEN() of Filename before
      IF LEN( cPath + cFile ) > 255
         System.Clipboard := cPath + cFile
         MsgInfo( "Filename > 255 (Filename was copy to Clipboard)", "Error MAX_PATH" )
         LOOP
but i did not get into that Code ... but later got MAX_PATH exceeded :(
do you mean this
#pragma BEGINDUMP
#include "hbapi.h"
   SHFILEOPSTRUCT sh;
#pragma ENDDUMP
In Unicode try change CHR( 0 ) for HB_UCHR( 0 )
srvet_claudio wrote: Sun Jul 04, 2021 10:54 pm In Unicode try change CHR( 0 ) for HB_UCHR( 0 )
THX for Answer
what do i have to include for HB_UCHR( 0 ) :?:
R:/Temp/hbmk_c45pjh.dir/SHELLOP.o:SHELLOP.c:(.data+0x1c8): undefined reference to `HB_FUN_HB_UCHR'
