index dbf character numbers
franco
Post by franco »
I started invoice 10000. Then later thought it would be wise to change when I changed from clipper to hmg to 100000 to keep then more uniform.
Can anyone think of a way to index these in order. This is a character field so 10002 comes after 100001.
This was a big mistake when searching in an index the numbers are all mixed up.
Thanks, Franco
All The Best,
Franco
Canada
dragancesu
DBs Used: DBF, MySQL, Oracle
Re: index dbf character numbers
Post by dragancesu »
Invoice number is numeric, why store in character field. Index number field os ok, it's in clipper and hmg
franco
Post by franco »
I use this thru program so was better a character, now is a delema.
I also have a date field in table. I have tried indexiny in inv + date but forgot to change date format to yymmdd I am going to try this.
All The Best,
Franco
Canada
SALINETAS24
Post by SALINETAS24 »
franco wrote: Tue Jun 08, 2021 4:05 pm I started invoice 10000. Then later thought it would be wise to change when I changed from clipper to hmg to 100000 to keep then more uniform.
Thanks, Franco
Hola Franco, para que el indice por un campo "ALFABETICO" tenga el mismo comportamiento que un indice por campo "NUMERICO", debes rellenar los espacios por CEROS "0"..., quedaria algo asi
0000001
0000002
0000003
0000010
0000011
0000012
0000101
0000102
0000110
0001000
0001001
0002010
0002030
0010000
0010001
0010002
Saludos y vamos con una cervecita bien fresca
ho,
i do use STRZERO() when convert Numeric to String to "hold LEN()" of String which a Index need
   cSeek := STRZERO(nNum, nLengh_of_Field) + DTOS(dDate)
Franco,
Once this occured to me also. I added new field (eg: NEW_INV_NO) with correct settings; filled it up with correct values; changed programs, indexes etc.
franco
Post by franco »
SALINETAS24, I can not add 0 before number because can not seek not knowing where number starts.
Serge, I have customers with 25 years of invoices and invoice items. It's hard to change their history.
the date did not work for me because 100898 come right after 10089.
Jimmy I will try to index on value then seek value.
Thanks to you all.
All The Best,
Franco
Canada
franco wrote: Tue Jun 08, 2021 11:59 pm Jimmy I will try to index on value then seek value.
create new Index this Way
   USE BLABLA EXCLUSIVE
   INDEX ON STRZERO(FIELD->ABC, 10)+DTOS(FIELD->DDATE) TO XYZ
so you can SEEK() this
   cSeek := STRZERO(nNum, 10) + DTOS(dDate)
   SEEK(cSeek)
AUGE_OHR wrote: Wed Jun 09, 2021 1:00 am hi,
   SEEK(cSeek)
franco wrote: Tue Jun 08, 2021 4:05 pm (...) This is a character field so 10002 comes after 100001.(...)
IMHO it should be like this:
INDEX ON Val ( Inv_Number ) TO indexfile
and Seek just like:
SEEK Val ( cSeek_Inv_Number )
franco
Post by franco »
I get argument error when trying to use strzero.
I can get seek to work. but I always browse the table before picking. This is when the order is not indexed by length of field.
browse gets
10001
10002
100021
10003
All The Best,
Franco
Canada
