Harbour MiniGUI Extended Edition build 21.05 is published
Hi Friends,
Edition.
Here's a breakdown of some of the modifications in the build 21.05.
* Improved output of the ErrorLog file:
- added possibility to modify the error message with using of
the public codeblock _HMG_bOnErrorInit;
- added possibility to modify the exit behavior with using of
the public codeblock _HMG_bOnErrorExit;
- added the filters (by Date, by StackTrace, by Error) in the
ErrorLog.htm file.
* Implementation of UNICODE support in the MiniGUI core:
- fixed problem with the handling of the internal strings in
the some controls.
* Added workaround for problem with command using FIELDS keyword.
* Updated HbZeeGrid library: pacified the missed C-warnings.
* Updated SQLite3 library to the recent version 3.36.0dev.
* Updated 'Open Table InSpector' sample:
- updated the source code for the OTIS library version 1.21 b01;
- updated documentation (look at \Doc folder).
* Added the new interesting samples, f.e.
HMG CASE tool for generate programs by Dragan Cizmarevic,
and updated some examples.
There are the separate versions of the MiniGUI library for ANSI and
UNICODE characters.
A setup of the ANSI build 21.05 for Borland C++ 5.8.2 is published at
the following URL:
There is also an extra donationware Minigui Ex build for the
Embarcadero C++ 10.2 ‘Tokyo’ compiler.
[MiniGUI Team]
Re: Harbour MiniGUI Extended Edition build 21.05 is published
Thank you !
Anand
Post by Anand »
Thank you Grigory for the new update.
Anand
salamandra
DBs Used: DBF, MySQL, SQL
Post by salamandra »
Thank you very much Grigory !!
Salamandra, Brazil
quartz565
Post by quartz565 »
Thank you Grigory!
Nikos.
os: Windows Server 2019 - 64
JALMAG
DBs Used: DBF, MariaDB
Post by JALMAG »
Thank yoy
The best Grigory
I've uploaded the updated setup of the build 21.05 for Borland C++ 5.8.2 at
Whatsnew:
* New: Added two auxiliary functions in \source\h_dbf_aux.prg:
- HMG_RecToHash( [cFieldList], [cNameList] ) --> hRec
Without any parameters, this function returns a hash with
all fieldnames as index and field values in the current work
area as values. When cFieldList is specified, the hash is
filled with the specified fields only.
When cNameList is specified, the names of the fields are
substituted by the names in the parameter.
- HMG_HashToRec( hRec, [cFieldList] ) --> lSaved
This function saves the values in the hash to the corresponding
fields in the DBF, locking and unlocking, if necessary.
* Updated: Implementation of UNICODE support in the MiniGUI core:
- fixed problem with the function FindWindowEx().
* Updated: HbSQLite3 library:
- update for using SQLITE3 latest version 3.36.0dev.
Contributed by Grigory Filatov <gfilatov@inbox.ru>.
* Updated: 'Dlu2Pixel Demo' sample.
Contributed by Sergej Kiselev
(see in folder \samples\Basic\GetBox_3)
* Updated: 'Is Exe Running' samples:
- using of the function FindWindowEx() instead of FindWindow().
(see demo.prg in folder \samples\Advanced\IsExeRunning)
* Updated: 'GraphPlus library demo' sample:
- added the header file GraphPlus.ch with predefined constants;
- modified method InitColors() for more noticeable color change;
- fixed the values percent calculation in the Pie graph;
- updated the centering of a graph title taking into account
the width of the legend at right;
- added the legend's centering in a bottom position.
(see in folder \samples\Advanced\GraphPlus)
Thanks for your attention and support.
[MiniGUI Team]
Whatsnew:
2021/06/17: HMG Extended Edition version 21.05 (Update 3).
* Modified: The some internal SetGet functions were defined as Static.
(see h_controlmisc.prg in folder \Source).
* Updated: Adaptation FiveWin Class TSBrowse 9.0 in HMG:
- minor correction in the method SetArrayTo in the TSBrowse class.
(see demo in folder \samples\Advanced\Tsb_SetArrayTo)
* Updated: 'GraphPlus library demo' sample.
Based upon a contribution of S.Rathinagiri <srgiri@dataone.in>
Adapted for Minigui Extended by Grigory Filatov <gfilatov@inbox.ru>
* Updated: 'Open Table InSpector' sample:
- updated the source code for the Otis library version 1.22 b01;
Contributed by Hans Marc.
- fixed a program crash at saving of the default settings;
- a code cleaning for warnings with Harbour switch -w2.
(see in folder \samples\Advanced\OTIS)
* Updated: 'Source Code Formatter' utility.
(see in folder \Utils\ofmt)
[MiniGUI Team]
Please note that there are also the following private MiniGUI (ANSi and UNICODE) builds for the all donators:
:arrow: - MinGW GNU C 11.1.1 (32-bit);
Minigui Ex Package (build date: 17.06.2021)
Download links: http://hmgextended.com/files/PRIVATE
Components versions:
Harbour MiniGUI Extended Edition 21.05 (Update 3)
Harbour 3.2.0dev (r2104281802)
Harbour Make (hbmk2) 3.2.0dev (r2021-04-28 18:02)
gcc (GCC with MCF thread model, built by LH_Mouse.) 11.1.1 20210604
:arrow: - MinGW GNU C 11.1.1 (64-bit);
Minigui Ex 64 Package (build date: 17.06.2021)
Harbour 3.4.0dev (cf51c11) (2017-12-20 13:44)
Harbour Make (hbmk2) 3.4.0dev (cf51c11) (2017-12-20 13:44)
gcc (MinGW-W64 x86_64-posix-seh, built by Brecht Sanders) 11.1.1 20210605
Thanks for your attention. 8-)
Whatsnew:
2021/06/24: HMG Extended Edition version 21.05 (Update 4).
* Fixed: Function ShellExecute() does not execute 32 bits applications
under Windows 10 64 bits in some cases.
This modification is useful for 32-bit applications that want
to gain access to the native system32 directory.
* Enhanced: The function WindowsVersion() detects Windows 10 release Id
and subversion build. Based upon a contribution of HMG user Jimmy.
(see demo in folder \samples\Applications\SysInfo)
- update for using SQLITE3 version 3.36.0 (from 3.36.0dev).
* New: 'Save/Load Array Items in Virtual Grid' sample.
Based upon a contribution of HMG user Edward
(see in folder \samples\Basic\Grid_Virtual_2)
* New: 'JSON ErrorLog Viewer' sample.
Contributed by Igor Nazarov.
Revised by Grigory Filatov <gfilatov@inbox.ru>
(see in folder \samples\Advanced\ErrorView)
[MiniGUI Team]
