who still can use 32 Bit Windows 10 OS Upgrades ?
since KB5000802 / KB5001330 / KB5003173 i have problem with 32 Bit Windows 10 Upgrades
! Note : it work with 64 Bit OS on same (!) PC ( Dual-boot )
after re-boot it "hang" at Windows Logo and Keyboard / Mouse does not reakt any more
i did test it again with lates Version get by "Media Creation Tool" on USB-Stick.
i did erase all on SSD before start from USB-Stick
after re-boot SSD "hang" again at Windows Logo :(
as i found out it is not only AsRock Mainboard with BIOS / UEFI
so i like to ask who still can use actuell 32 Bit Windows OS Upgrades :?:
which Mainboard still work :idea:
my AsRock "DeskMini 110" and "Z170 Gaming K6" does fail
dragancesu
DBs Used: DBF, MySQL, Oracle
Re: who still can use 32 Bit Windows 10 OS Upgrades ?
Post by dragancesu »
New and old are not easy when it comes to windows. The new motherboard/chipset are designed (I would say locked) for windows 10 and it works.
If you are a serious developer (you are) then I suggest you use VM - virtual box
I had one H110 board, even with windows 7-64 there were problems
Claudio Ricardo
DBs Used: DBF, MySQL, MariaDB
Post by Claudio Ricardo »
You are right Dragancesu, since 2012 I use GNU-Linux as my base operating system
and with VirtualBox the Windows I need, If it fails I restore the .vdi file from the backup in a few seconds,
it is also very easy to test the programs in different versions of Windows.
i have made a small App, using WMI, to get Information i want.
it does not get any "personal" Information only Hardware which run under 32 Bit OS
please if you have a running 32 Bit OS use that Code and post you "Info.TXT" here in Forum, THX
RUNW32.ZIP
Detect Hardware using WMI
(2.48 KiB) Downloaded 109 times
my AsRock DeskMini 110
HMG 3.4.4 Stable (32 bits)MinGW GNU C 5.3 (32-bit)
WIN Professional Build 19043 32 Bit
Available RAM : 1272 MB
Total Memory : 3157 MB
BoardInfo
Manufacturer : ASRock
Product : H110M-STX
BIOSInfo
Manufacturer : American Megatrends Inc.
Name : BIOS Date: 04/01/19 20:44:20 Ver: 05.0000B
Date : 20190401
Version : ALASKA - 1072009
BIOS Version : P8.10
MemoryInfo
BankLabel : BANK 0
Capacity : 8589934592
ClockSpeed : 2133
Voltage : 1200
Device : ChannelA-DIMM0
FormFactor : SODIMM
Manufacturer : 1315
PartNumber : CT8G4SFS824A.C8FDD1
MemoryType : DDR4
Speed : 2133
BankLabel : BANK 2
ClockSpeed : 2133
Voltage : 1200
Device : ChannelB-DIMM0
FormFactor : SODIMM
Manufacturer : Micron
PartNumber : 8ATF1G64HZ-2G3B1
MemoryType : DDR4
Speed : 2133
ProcessorInfo
Manufacturer : GenuineIntel
Description : x64 Family 6 Model 94 Stepping 3
Model : Intel(R) Core(TM) i7-6700TE CPU @ 2.40GHz
Cores : 4
Logical : 8
Hyper-Threading : Enabled
Current Speed : 2401 MHz
Max Speed : 2401 MHz
Ext Clock : 100 MHz
! Note : have used "windows10.0-kb5000736-x86_428ba21ee5118bac619f4de6977de69c1f65b066" so "real" it is 19042
here another AsRock Mainboard where i do run "Windows Insider 21387 32 Bit"
( but it fail with B5000802 / KB5001330 / KB5003173 )
WIN Professional Build 21387 32 Bit
Available RAM : 1485 MB
Total Memory : 3051 MB
BoardInfo
Product : Z170 Gaming K6
BIOSInfo
Name : BIOS Date: 10/18/18 19:36:58 Ver: 05.0000B
Date : 20181018
BIOS Version : P7.50
MemoryInfo
BankLabel : BANK 0
ClockSpeed : 3600
Voltage : 1350
FormFactor : DIMM
Manufacturer : 1315
PartNumber : BL8G36C16U4B.M8FE1
MemoryType : DDR4
Speed : 3600
ProcessorInfo
Model : Intel(R) Core(TM) i7-6700 CPU @ 3.40GHz
Cores : 4
Logical : 8
Current Speed : 3401 MHz
Max Speed : 3401 MHz
Ext Clock : 100 MHz
dragancesu
Run on old computer (win 7 32bit)
dragancesu wrote: Fri May 28, 2021 6:12 am Run on old computer (win 7 32bit)
did you got a Error on Win 7 ( can´t read it ) :?:
dragancesu
Yes, this is screen shot on win7 32 bit
dragancesu wrote: Fri May 28, 2021 4:09 pm Yes, this is screen shot on win7 32 bit
it is this line
      ? cInfo += "ClockSpeed      : " + TRIM_NUMBER( oMemory:ConfiguredClockSpeed ) + CRLF
as WMI use Hardware Information it might that some Property does not exist.
so try to comment it out.
as this line (most) give same Result
      ? cInfo += "Speed           : " + TRIM_NUMBER( oMemory:Speed ) + CRLF
it seems "more stable"
here you can download a small Tool "WMI Creator" by Microsoft.
https://www.microsoft.com/en-us/downloa ... px?id=8572
The WMI Code Creator tool allows you to generate VBScript, C#, and VB .NET code that uses WMI to complete a management task such as querying for management data, executing a method from a WMI class, or receiving event notifications using WMI.
