grid dblclick
franco
Re: grid dblclick
Post by franco »
Thanks Jimmy, I will try and let you know.
I got around stopping dblclick on cell 2 with the following which now all works.
There may be some here to help someone else.
#include "HMG.CH"
# define blue (0,128,255)
FUNCTION main()
PRIVATE acell, GL:= 0
OPNFLS()
	DEFINE WINDOW Form_1 ;
		AT 10,0 ;
		WIDTH 1000 HEIGHT 900 ;
		TITLE 'HMG Grid Demo' ;
		Modal
		DEFINE BUTTON button_1
		          ROW 800
			  COL 490
			  WIDTH 120
			  HEIGHT 30
			  CAPTION "SAVE && EXIT"
                          ACTION Form_1.Release
		   END BUTTON
		DEFINE GRID Grid_2
			ROW	60
			COL	20        //140
			WIDTH 490        //1100
			HEIGHT 325 // 310    //370
			BACKCOLOR  { 180, 180, 200}
			FONTCOLOR  { 0, 0, 0 }
			HEADERS {'Item','Qty','Description','Sellprice','Total'}
			WIDTHS {100,70,100,90,100 }
			COLUMNCONTROLS { {'TEXTBOX','CHARACTER','!!!!!!!!!!!!!!!'},{'TEXTBOX','NUMERIC','9999.99'},;
				{'TEXTBOX','CHARACTER','!!!!!!!!!!!!!!!'},;
				{'TEXTBOX','NUMERIC','9999999.99'},{'TEXTBOX','NUMERIC','9999999.99'}}
			ROWSOURCE "PITEM"
			COLUMNFIELDS { 'ITEM' , 'QTY','DESC', 'PRICE','VAL(STR(QTY*PRICE,10,2))'}
			JUSTIFY { GRID_JTFY_LEFT,GRID_JTFY_RIGHT,GRID_JTFY_LEFT, GRID_JTFY_RIGHT,GRID_JTFY_RIGHT }
			COLUMNWHEN { { || .F. },{ || iIf(HMG_GetLastVirtualKeyDown() == 13, .T., .F.)}, { || .T. },{ || .T. },{ || .F. }}
			ONHEADCLICK { {|| msgbox(item) }, {|| chinv() },{ || '' }, {|| '' }, { || ''} }
			VALUE {1,1}
			CELLNAVIGATION .F.
			ONCHANGE  { || {CH4()}}
			ALLOWEDIT .T.
			LOCKCOLUMNS 5
		*	ALLOWDELETE .T.
		END GRID
  CENTER WINDOW Form_1
  ACTIVATE WINDOW Form_1
FUNCTION CH4
Local aCell ,   AcellValue, Change:=0    //********************** BEFORE EVERY RETURN NEEDS A HMG_CleanLastVirtualKeyDown()
PRIVATE OQty:= 0, Nqty:= 0, Inum := '', Qd:= 0
aCell:= Form_1.Grid_2.value
IF aCell[2] = 2 .AND. HMG_GetLastVirtualKeyDown() == 13
	select pitem
	Go Form_1.Grid_2.Recno               //sets the pinv_it file to grid
	INum := ALLTRIM(ITEM)
	select inv
	seek INum
        if found()
		if rlock()
			select pitem
			msginfo('Inventory Item in Use ** Try Later')
			Form_1.Grid_2.ClearBuffer
			Form_1.Grid_2.value:=aCell
			return
	select pitem
	OQty := VAL(ALLTRIM(STR(PITEM->QTY,10,2)))
	Nqty := Form_1.Grid_2.CellEx (aCell[1] , aCell[2])
	Qd := val(alltrim(str(oQty,10,1)))-val(alltrim(str(nQty,10,2)))
	if rlock()
		replace qty with Nqty
		msginfo('Can Not Lock Item')
		select inv
		unlock
		select pitem
		return
***************** Inventory Update
	select Inv
		replace qty with qty + Qd
	unlock
	select pitem
	Form_1.Grid_2.Refresh
Function chinv
go form_1.grid_2.recno
select inv
seek pitem->item
msgbox(num1 + " On Hand "+ALLTRIM(str(INV->qty))+ "  "+PITEM->ITEM)
select pitem
return
FUNCTION CLOSEFLS
	CLOSE PITEM
	CLOSE INV
	CLEAR ALL
FUNCTION OPNFLS
LOCAL CF, indcode := 65, IND:= '', KY := 'R'
if ! file('inv.dbf')
	CF := {}
	aADD(CF,{'NUM1'       ,'C' , 15,0})
	aADD(CF,{'DESC'       ,'C' , 15,0})
	aADD(CF,{'PRICE'       ,'N' ,10,2 })
	aADD(CF,{'QTY'       ,'N' ,10,0 })
	DBCREATE( 'INV.DBF',CF )
	USE
   USE INV EXCLUSIVE NEW
	DO WHILE RECNO()< 5
*	IND := 'CHR('+ALLTRIM(STR(INDCODE))+')'
	INV->( DBAPPEND())
	INV->( FIELDPUT(1, 'P'+ALLTRIM(STR(100000+RECNO())) ))
	INV->( FIELDPUT(2, 'PARTS'))
	INV->( FIELDPUT(3, 24.95 - (RECNO()*3)))
	INDCODE:=INDCODE+1
	LOOP
	ENDDO
	INDEX ON NUM1 TO NUM1
	REPLACE ALL QTY WITH 1
	USE
SELECT 0
USE INV NEW SHARED
SET INDEX TO NUM1
GO 3
*RLOCK()
*INDEX ON ITEM TO ITEM
*NORD := INDEXORD()
if ! file('pitem.dbf')
	CF := {}
	aADD(CF,{'PRICE'       ,'N' ,10,2})
	aADD(CF,{'QTY'       ,'N' ,10,2})
	aADD(CF,{'ITEM'       ,'C' , 15,0})
	DBCREATE( 'PITEM.DBF',CF )
	USE
    USE PITEM EXCLUSIVE NEW
       APPEND FROM INV
       REPLACE ALL ITEM WITH NUM1
	INDEX ON ITEM TO NUM1
	USE
	SELECT 0
	USE PITEM SHARED
*	SET INDEX TO ITEM
All The Best,
Franco
Canada
franco
Re: grid dblclick
Post by franco »
New problem in grid column 2. When changing the value in the column I press enter to open the cell to change. If I change the value but do not press
enter to close the cell change but take the mouse and press anywhere away from the cell line I am on the program can carry on to different area.
Is there a way to shut the mouse off or is there a way to not allow exiting the cell 2 until the change is completed.
On change is not triggered until enter is pressed again, so the on change function is not processed.
Any thoughts, Franco
All The Best,
Franco
Canada
franco
Re: grid dblclick
Post by franco »
Found a way to get to work. Had to add a Function on the LOSTFOCUS of grid.
ONLOSTFOCUS CH3()
FUNCTION CH3
LOCAL NQ, aCell:= Form_1.Grid_2.value
SELECT PITEM
NQ := Form_1.Grid_2.CellEx (aCell[1] , aCell[2])
IF ACELL[2] = 2 .AND. PITEM->QTY <> NQ .AND. HMG_GetLastVirtualKeyDown() <> 13
			select pitem
			msginfo('Quantity Not Set ** Returning To Reset Quantity')
			aCell[2] = 2
All The Best,
Franco
Canada
