Saving Tree to a file
HGAutomator
Post by HGAutomator »
I've looked at all the Tree Samples, and the only SaveAs option is a bitmap. Are there are any existing snippets for saving a tree to xml or json, or to a database?
Re: Saving Tree to a file
I would like to have that too!
I don't think there is a ready solution for exporting / importing trees, but you can easily build your own solutions.
Below I present the code that allows you to write and read the tree structure to a file in json format.
It is not a ready-made universal tool and it will certainly not work in all applications, but it shows how the tree structure export / import operation can be quite easily accomplished.
I chose the json format so that tasks would be performed on arrays, but you can successfully (with a little modification) use a DBF file.
Tree_99.7z
(4.11 KiB) Downloaded 177 times
For exercise purposes, try to expand the export / import functions with e.g. information which nodes are expanded and which are collapsed. :mrgreen:
By the way, I found a strange bug in the DeleteAllItems method. It has something to do with the use of the GetFile / PutFile function, but I can't find the reason. You can observe this error by following these steps:
For the GetFile function:
1. Click the "Delete All / Add Test" button
2. Click the "Load Tree Stru" button
3. Cancel loading the file.
4. Click the "Delete All Items" button
For the PutFile function:
2. Click the "Save Tree Stru" button
3. Cancel saving the file.
For this reason, in my tree structure import function, I used this snippet of code instead of the DeleteAllItems method:
Do While GetProperty ( cFormName, cTreeName, "ItemCount" ) > 0
     DO Events
     DoMethod( cFormName, cTreeName, "DeleteItem", GetProperty ( cFormName, cTreeName, "ItemCount" ) )
Enddo
Enjoy.
Thanks !
HGAutomator
Very nice, that's a start. Thanks, edk.
AidTIC
Post by AidTIC »
Sabríais si hay algún tamaño máximo para variables json?
viewtopic.php?f=24&t=6925&p=66502&hilit=json#p66502
Skydone Solutions
www.skydone.com
