Harbour MiniGUI Extended Edition build 21.03 is published
Hi Friends,
Edition.
Here's a breakdown of some of the modifications in the build 21.03.
* Implementation of UNICODE support in the MiniGUI core libraries.
It was a postponed user's request (slight chance of regression).
* The useful Registry functions were updated for using into the
Unicode build.
* Fixed ANIGIF control:
- restored a proper handling of the DELAY clause
(bug was introduced in the build 20.10 (update 2)).
* The Tab page(s) at owner-draw colored TAB control supports now
PNG, GIF and TIF images. The 'Transparent' property will be added
to these images automatically.
* Updated BosTaurus, Debugger, HbPrinter, MiniPrint, MiniPrint2 and
TSBrowse libraries.
* Updated SQLite3 library to the recent version 3.35.3.
* Updated 'Open Table InSpector' sample:
- added the source code for the OTIS library version 1.20 b01;
- updated documentation (look at \Doc folder).
* Updated some examples for UNICODE support.
There are the separate versions for ANSI and UNICODE charsets of the
MiniGUI library now.
A setup of the ANSI build 21.03 for Borland C++ 5.8.2 is published at
the following URL:
There is also an extra donationware Minigui Ex build for the
Embarcadero C++ 10.2 ‘Tokyo’ compiler.
[MiniGUI Team]
P.S. I have also prepared an archive with UNICODE version of the library
for all donators.
Re: Harbour MiniGUI Extended Edition build 21.03 is published
Thanks a lot !
Anand
Post by Anand »
Thanks a lot Grigory , for the new update and UNICODE version.
Anand
Anand
hmgaams57
Post by hmgaams57 »
Many thanks Grigory
Claudio Ricardo
DBs Used: DBF, MySQL, MariaDB
Post by Claudio Ricardo »
Thanks for you effort Grigory !!!
salamandra
DBs Used: DBF, MySQL, SQL
Post by salamandra »
Thank you very much Grigory !!
Salamandra, Brazil
JALMAG
DBs Used: DBF, MariaDB
Post by JALMAG »
Thank you Grigory, modest financial contribution
quartz565
Post by quartz565 »
Thank you very much Grigory !!!
Nikos.
os: Windows Server 2019 - 64
Thanks grigory congratulation
I've uploaded the updated setup of the build 21.03 (Update 1) for Borland C++ 5.8.2 at
Whatsnew:
* New: Implementation of UNICODE support in the MiniGUI core libraries:
- updated the Harbour TGet class;
- updated the GETBOX control;
- updated the TSBrowse library.
* Updated: Adaptation FiveWin Class TSBrowse 9.0 in HMG:
- correction of using the variable :lNoKeyChar with the logical
fields in the method KeyChar().
Contributed by SergKis
* Updated: HbSQLite3 library:
- update for using SQLITE3 version 3.35.4 (from 3.35.3).
Contributed by Grigory Filatov <gfilatov@inbox.ru>.
* Updated: Harbour Compiler 3.2.0dev (SVN 2021-03-31 20:37):
* Updated: PostGreSQL library source code
(see in folder \Source\HbPgSql).
(look at ReadMe.txt in folder \harbour)
* Updated: 'Test application' sample.
- updated C-code for unicode support.
(see in folder \samples\Basic\TEST_APPLICATION)
* Updated: 'Using OOP events for creation of the reports' sample:
- updated database for unicode compatibility.
Contributed by Sergej Kiselev
(see in folder \samples\Advanced\APP_OOPREPORT)
Thanks for your attention and support.
[MiniGUI Team]
