Event for moving a window
hmgchang
Post by hmgchang »
Hola Masters,
i can use ON SIZE event when i size a window,
but how about moving a window... any ON MOVE ?
or how can i catch the move event ?
Thks n rgds
Chang
Just Hmg It !
Re: Event for moving a window
Maybe...
OnMouseDrag Event
Occurs when the user drag in a Window
Syntax:
OnMouseDrag <ActionProcedure>
The following data are available at ‘OnMouseClick’ procedure:
_HMG_SYSDATA [ 191 ] -> Mouse Row
_HMG_SYSDATA [ 192 ] -> Mouse Col
hmgchang
Post by hmgchang »
Hola and thanks Andy,
it happen if the mouse pointer is inside the window that wont cause the window
to move.
When we move window the mouse is at the title bar of the window,
that what can move the whole window across the screen,
unfortunately i don't know what event to check ( ON MOVE ?)
Thks n Rgds
Chang
HMG -
Happy Make Good
Just Hmg It !
do you you wat to move hole Window :?:
   MoveWindow( hWnd, col, row, width, height, .T. )
Source is in x:\hmg.3.4.4\SOURCE\c_windows.c
hmgchang
Post by hmgchang »
Hi Auge_OHR,
thks for the info.
Pls be kind to give a ssw ( small simple working) example
with hmg since I never learn C.
Thks n Rgds
Chang
Just Hmg It !
Claudio Ricardo
DBs Used: DBF, MySQL, MariaDB
Post by Claudio Ricardo »
Hi... Maybe:
PRIVATE nRow, nCol
	Load Window Main
	Main. Center
		nRow := GetProperty ("Main" , "Row")
		nCol := GetProperty ("Main" , "Col")
	Main. Activate
Function OnMove
	If nRow <> GetProperty ("Main" , "Row") .OR. nCol <> GetProperty ("Main" , "Col")
		MsgInfo ("La ventana se ha movido !" , "Aviso !")
	EndIf
In Main.fmg set:
OnMouseMove OnMove ()
